Offline
Jr. Member
« on: May 26, 2011, 09:49:03 am » |
hey guys im building a robot that we are going to race with mostley left habd turns. i am having a few issues with the code and would like to get your opinions. the main thing is it dont respond quick enough and runs into walls and well flat out i havent gotten it to turn yet heres the code. i have a ping sensor as my distance finder and im sweeping it on a servo #include <Servo.h> Servo myservo; // create servo object to control a servo const int pingPin = 8; //ping sensor pin number int pos = 90; // variable to set the initial position of the servo const int ping = 8; //ping pin number int reset = 2;// motordriver reset pin number void setup() { Serial.begin(9600); //sets serial communication bps pinMode (reset, OUTPUT); digitalWrite(reset,LOW); delay(50); digitalWrite(reset,HIGH); delay(50); myservo.attach(10); // attaches the servo on pin 10 to the servo object myservo.write(90); //center servo delay(500); //delay 1000ms } void loop() { long duration, inches, inches2, inches3; // establish variables for duration of ping, inches = 90; inches2 = 20; inches3 = 140 myservo.write(90); //move servo to pos 0 delay(5); pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches = microsecondsToInches(duration); delay(500); myservo.write(20); //move servo to pos 20 delay(5); pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches2 = microsecondsToInches(duration); delay(500); myservo.write(90); //move servo to pos 0 delay(5); pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW); pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH); inches = microsecondsToInches(duration); delay(500); myservo.write(140); //move servo to pos 0 delay(5); pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW); pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH); inches = microsecondsToInches(duration); delay(500); myservo.write(90); //move servo to pos 0 delay(5); pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW); pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH); inches3 = microsecondsToInches(duration); delay(500); if(inches > 50 ){ //left motor unsigned char buff1[6]; buff1[0]=0x80; //start byte buff1[1]=0x00; //device type buff1[2]=0x01; //motor number and directiobyte; motor one =00,01 buff1[3]=0x7F; //motor speed 0 to 128 in hex (ex 100 is 64 hex) for (int i=0; i<4; i++) {Serial.print(buff1[i],BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x03; //motor and direction byte; motor two=02.03 buff2[3]=0x7E;//7E is 126 in hex; 7D is 125 in hex set to smaller value to compensate for uneven wheel speed??? for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } if (inches2 < 12 ){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x40; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } if ( inches < 50 && inches3 < 12 ){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x40; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } if (inches3 < 12){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x7F; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } } long microsecondsToInches(long microseconds) { return microseconds / 74 / 2; }
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #1 on: May 26, 2011, 09:57:07 am » |
Doesn't respond very quickly, you say?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
New Hampshire
Offline
God Member
There are 10 kinds of people, those who know binary, and those who don't.
« Reply #2 on: May 26, 2011, 09:59:08 am » |
You're doing 5 range readings in a row with 500ms delays in between. That's over 2.5 seconds where the Arduino will be unable to do anything else. Of course it's going to run into stuff.
First, do NOT use delay(). It's bad. The Arduino will do nothing else at all for that 500ms. Look at the Blink without Delay example for how to time events without blocking any other processing.
Also, your sensor should be pointed straight ahead while moving forward, not sweeping. You only sweep if it detects an obstacle in your way to find a new path to go in. And when you're sweeping, the robot should be stopped.
Logged
Offline
Jr. Member
« Reply #3 on: May 26, 2011, 10:21:12 am » |
ok i will take out the delays, and so should i put my if statements in with the loop where im sweeping the servo or put them outside the loop? and ill try keeping it forward when we are going strait
Logged
Offline
Jr. Member
« Reply #4 on: May 26, 2011, 10:58:03 am » |
ok i re wrote a few things see what you think heres the new code. #include <Servo.h> Servo myservo; // create servo object to control a servo const int pingPin = 8; //ping sensor pin number int pos = 90; // variable to set the initial position of the servo const int ping = 8; //ping pin number int reset = 2;// motordriver reset pin number void setup() { Serial.begin(9600); //sets serial communication bps pinMode (reset, OUTPUT); digitalWrite(reset,LOW); delay(50); digitalWrite(reset,HIGH); delay(50); myservo.attach(10); // attaches the servo on pin 10 to the servo object myservo.write(90); //center servo delay(500); //delay 1000ms } void forward() { //left motor unsigned char buff1[6]; buff1[0]=0x80; //start byte buff1[1]=0x00; //device type buff1[2]=0x00; //motor number and directiobyte; motor one =00,01 buff1[3]=0x7F; //motor speed 0 to 128 in hex (ex 100 is 64 hex) for (int i=0; i<4; i++) {Serial.print(buff1[i],BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7E;//7E is 126 in hex; 7D is 125 in hex set to smaller value to compensate for uneven wheel speed??? for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void rightWall(){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x40; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void leftWall(){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x7F; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void reverse(){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x01; buff3[3]=0x45; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x03; //motor and direction byte; motor two=02.03 buff2[3]=0x45; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void leftTurn(){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x45; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void rightTurn(){ //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x7F; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);} //right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x45; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void loop(){ { long duration, inches, inches2, inches3; // establish variables for duration of ping, inches = 90; inches2 = 20; inches3 = 140 myservo.write(90); //move servo to pos 0 delay(5); pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches = microsecondsToInches(duration); myservo.write(20); //move servo to pos 20 delay(5); pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches2 = microsecondsToInches(duration); myservo.write(90); //move servo to pos 0 delay(5); pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW); pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH); inches3 = microsecondsToInches(duration); } } long microsecondsToInches(long microseconds) { return microseconds / 74 / 2; } void wall() } if(inches > 50 ){ forward(); } if (inhes2 < 12){ rightWall(); } if (inches3 < 12){ leftWall(); } if (inches < 50 && inches3 < 12){ lerftTurn(); } if (inches < 50 && inches2 < 12){ rightTurn(); } }
and heres the report i get when i compile it sketch_may26c:175 error: expected initializer before '}' token sketch_may26c:175 error: expected declaration before '}' token
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #5 on: May 26, 2011, 11:30:16 am » |
Perhaps if you used random indenting, and random amounts of white space, you could mask where the curly braces don't match better.
There is a reason that code is indented, and that people make the effort to match indent levels for { and } (and put them on lines by themselves).
There's even a tool in the IDE to format the code for you.
Logged
Des Moines, WA - USA
Offline
God Member
« Reply #6 on: May 26, 2011, 05:09:42 pm » |
PaulS is much like sandpaper. He starts off in the 40-60 grit range and, if you can stand the "rub", eventually works his way to applying a 80-120 grit.
In other words - he's a but rough at first but if you're patient things'll eventually smooth out and you learn things along the way.
Logged
Offline
Jr. Member
« Reply #7 on: May 26, 2011, 10:14:59 pm » |
lol ok ill just do that then. i rewrote my code tryng to use functions and subroutines like a good feller. and like everyone has been saying to do in the post i have read. it compiles fine but wont start up my motordriver everything else works great te ping ans sweep do exactley what want them to do. but no motors  pls help i am currently trying again and race for class is next week  i know motordriver works i can get it to work on its own and with the sweep and ping and respond to the ping but would like to have the subroutines and the servo dont like not hving the delays between the pings #include <Servo.h> Servo myservo; // create servo object to control a servo const int ping = 8; //ping sensor pin number int pos = 90; // variable to set the initial position of the servo int reset = 2;// motordriver reset pin number
void setup() { Serial.begin(9600); //sets serial communication bps pinMode (reset, OUTPUT); digitalWrite(reset,LOW); delay(50); digitalWrite(reset,HIGH); delay(50); myservo.attach(10); // attaches the servo on pin 10 to the servo object myservo.write(90); //center servo delay(400); //delay 1000ms }
inches = microsecondsToInches(duration); delay (400);
inches2 = microsecondsToInches(duration); delay (400);
pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches = microsecondsToInches(duration); delay (400);
myservo.write(140); //move servo to pos 0 delay(5); pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches3 = microsecondsToInches(duration); delay (400); myservo.write(90); //move servo to pos 0 delay(5);
pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW); pinMode(ping, INPUT); duration = pulseIn(ping, HIGH); inches = microsecondsToInches(duration); delay(100);
if(inches > 50 ) forward();
if (inches2 < 12) rightWall(100);
if (inches3 < 12) leftWall(100);
if (inches < 50 && inches3 > 52) leftTurn(2000);
if (inches < 50 && inches2 > 52) rightTurn(2000); } long microsecondsToInches(long microseconds) { return microseconds / 74 / 2; } void wall() { long duration, inches, inches2, inches3; // establish variables for duration of ping, inches = 90; inches2 = 20; inches3 = 140 {
void forward(){ //left motor unsigned char buff1[6]; buff1[0]=0x80; //start byte buff1[1]=0x00; //device type buff1[2]=0x00; //motor number and directiobyte; motor one =00,01 buff1[3]=0x7F; //motor speed 0 to 128 in hex (ex 100 is 64 hex) for (int i=0; i<4; i++) {Serial.print(buff1[i],BYTE);}
//right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7E;//7E is 126 in hex; 7D is 125 in hex set to smaller value to compensate for uneven wheel speed??? for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void rightWall(int duration) { //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x40; for(int i=0; i<4; i++){Serial.print(buff3[i], BYTE);}
void leftWall(int duration) { //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x7F; for(int i=0; i<4; i++) { Serial.print(buff3[i], BYTE);}
//right motor unsigned char buff2[6]; buff2[0]=0x80; buff2[1]=0x00; buff2[2]=0x02; //motor and direction byte; motor two=02.03 buff2[3]=0x7D; for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);} } void reverse(int duration) { //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x01; buff3[3]=0x45; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);}
void leftTurn(int duration) { //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x45; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);}
void rightTurn(int duration) { //left motor unsigned char buff3[6]; buff3[0]=0x80; buff3[1]=0x00; buff3[2]=0x00; buff3[3]=0x7F; for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);}
« Last Edit: May 26, 2011, 10:19:20 pm by drab »
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #8 on: May 27, 2011, 01:35:08 am » |
Do yourself a favour - shorten your code with a single range function, instead of typing the same code over and over again: long getRangeInInches (int ping) { pinMode(ping, OUTPUT); digitalWrite(ping, LOW); delayMicroseconds(2); digitalWrite(ping, HIGH); delayMicroseconds(5); digitalWrite(ping, LOW);
pinMode(ping, INPUT); long duration = pulseIn(ping, HIGH);
return microsecondsToInches(duration); } With shorter code, it may make it easier for you to see where you are overwriting results. Do the rest of us a favour by typing ctrl-T in the IDE before posting your code.
« Last Edit: May 27, 2011, 01:38:08 am by AWOL »
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #9 on: May 27, 2011, 01:56:32 am » |
Humans are really bad at repetition; computers are really good at it. void forward() { moveMotor (0, 0x7F); moveMotor (2, 0x7E); }
void rightWall(int duration) { moveMotor (0, 0x40); moveMotor (2, 0x7D); }
void leftWall(int duration) { moveMotor (0, 0x7F); moveMotor (2, 0x7D); }
void reverse(int duration) { moveMotor (1, 0x45); moveMotor (3, 0x45); }
void leftTurn(int duration) { moveMotor (0, 0x45); moveMotor (2, 0x7D); }
void rightTurn(int duration) { moveMotor (0, 0x7F); moveMotor (2, 0x45); }
void moveMotor (unsigned char motor, unsigned char speed) { unsigned char buff[4]; //left motor buff[0]=0x80; buff[1]=0x00; buff[2]=motor; buff[3]=speed; for(int i=0; i<4; i++) { Serial.print(buff[i], BYTE); } }
Reducing source size gives bugs fewer dusty corners to hide in.
Logged
Offline
Jr. Member
« Reply #10 on: May 28, 2011, 08:04:35 pm » |
Hey awol thx for the response ill put that together tonight. I have a working one but its pretty long and repedative. But it works and the race for class is on thursday the 2nd so i really apreciate the help thx again I
Logged
