Topic: robot that should turn left on its own and keep itself going strait (Read 2416 times) previous topic - next topic
drab
hey guys im building a robot that we are going to race with mostley left habd turns. i am having a few issues with the code and would like to get your opinions. the main thing is it dont respond quick enough and runs into walls and well flat out i havent gotten it to turn yet heres the code. i have a ping sensor as my distance finder and im sweeping it on a servo
        #include <Servo.h>
          Servo myservo;  // create servo object to control a servo
          const int pingPin = 8;  //ping sensor pin number
          int pos = 90;    // variable to set the initial position of the servo
          const int ping = 8; //ping pin number
          int reset = 2;// motordriver reset pin number
          Serial.begin(9600); //sets serial communication bps
          pinMode (reset, OUTPUT);
          digitalWrite(reset,LOW);
          delay(50);
          digitalWrite(reset,HIGH);
          delay(50);
          myservo.attach(10);  // attaches the servo on pin 10 to the servo object
          myservo.write(90); //center servo
          delay(500); //delay 1000ms
            long duration, inches, inches2, inches3; // establish variables for duration of ping, inches = 90; inches2 = 20; inches3 = 140
          myservo.write(90); //move servo to pos 0
          delay(5);
              pinMode(ping, OUTPUT);
               digitalWrite(ping, LOW);
               delayMicroseconds(2);
               digitalWrite(ping, HIGH);
               delayMicroseconds(5);
                pinMode(ping, INPUT);
              duration = pulseIn(ping, HIGH);
              inches = microsecondsToInches(duration);
          myservo.write(20); //move servo to pos 20
          delay(5);
                inches2 = microsecondsToInches(duration);
          delay(5);
              pinMode(pingPin, OUTPUT);
              digitalWrite(pingPin, LOW);
              digitalWrite(pingPin, HIGH);
               pinMode(pingPin, INPUT);
              duration = pulseIn(pingPin, HIGH);
           myservo.write(140); //move servo to pos 0
           delay(5);
          delay(5);
               inches3 = microsecondsToInches(duration);
         if(inches > 50 ){
                   //left motor
                unsigned char buff1[6];
                buff1[0]=0x80; //start byte
                buff1[1]=0x00; //device type
                buff1[2]=0x01; //motor number and directiobyte; motor one =00,01
                buff1[3]=0x7F; //motor speed 0 to 128 in hex (ex 100 is 64 hex)
                for (int i=0; i<4; i++) {Serial.print(buff1[i],BYTE);}
                //right motor
               unsigned char buff2[6];
               buff2[0]=0x80;
               buff2[1]=0x00;
               buff2[2]=0x03; //motor and direction byte; motor two=02.03
               buff2[3]=0x7E;//7E is 126 in hex; 7D is 125 in hex set to smaller value to compensate for uneven wheel speed???
               for(int i=0; i<4; i++) {Serial.print(buff2[i],BYTE);}
           if (inches2 < 12 ){
             //left motor
                  unsigned char buff3[6];
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x40;
                  for(int i=0; i<4; i++) {Serial.print(buff3[i], BYTE);}
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[2]=0x02; //motor and direction byte; motor two=02.03
                 buff2[3]=0x7D;
          if ( inches  < 50 && inches3 < 12 ){
                       //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x40;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x7D;
        if (inches3 < 12){
            //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x7F;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x7D;
          long microsecondsToInches(long microseconds)
           return microseconds / 74 / 2;
AWOL
jraskell
You're doing 5 range readings in a row with 500ms delays in between.  That's over 2.5 seconds where the Arduino will be unable to do anything else.  Of course it's going to run into stuff.
First, do NOT use delay().  It's bad.  The Arduino will do nothing else at all for that 500ms.  Look at the Blink without Delay example for how to time events without blocking any other processing.
Also, your sensor should be pointed straight ahead while moving forward, not sweeping.  You only sweep if it detects an obstacle in your way to find a new path to go in.  And when you're sweeping, the robot should be stopped.
drab
ok i will take out the delays, and so should i put my if statements in with the loop where im sweeping the servo or put them outside the loop?
and ill try keeping it forward when we are going strait
drab
ok i re wrote a few things see what you think heres the new code.
#include <Servo.h>
  delay(50);
  delay(50);
  void forward()
      //left motor
                buff1[2]=0x00; //motor number and directiobyte; motor one =00,01
                //right motor
               buff2[0]=0x80;
               buff2[1]=0x00;
    void rightWall(){
       //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x40;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x7D;
   void leftWall(){
                    //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x7F;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x7D;
     void reverse(){
        //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x01;
                  buff3[3]=0x45;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x45;
        void leftTurn(){
             //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x45;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x7D;
        void rightTurn(){
           //left motor
                  buff3[0]=0x80;
                  buff3[1]=0x00;
                  buff3[2]=0x00;
                  buff3[3]=0x7F;
                  //right motor
                 buff2[0]=0x80;
                 buff2[1]=0x00;
                 buff2[3]=0x45;
        void loop(){
          delay(5);
          delay(5);
          delay(5);
   void wall()
      if(inches > 50 ){
        forward();
      if (inhes2 < 12){
        rightWall();
      if (inches3 < 12){
        leftWall();
      if (inches < 50 && inches3 < 12){
        lerftTurn();
      if (inches < 50 && inches2 < 12){
        rightTurn();
and heres the report i get when i compile it
sketch_may26c:175 error:  expected initializer before '}' token
sketch_may26c:175 error:  expected declaration before '}' token
PaulS
Perhaps if you used random indenting, and random amounts of white space, you could mask where the curly braces don't match better.
There is a reason that code is indented, and that people make the effort to match indent levels for { and } (and put them on lines by themselves).
There's even a tool in the IDE to format the code for you.
lloyddean
PaulS is much like sandpaper.  He starts off in the 40-60 grit range and, if you can stand the "rub", eventually works his way to applying a 80-120 grit.
In other words - he's a but rough at first but if you're patient things'll eventually smooth out and you learn things along the way.
drab
lol ok ill just do that then. i rewrote my code tryng to use functions and subroutines like a good feller. and like everyone has been saying to do in the post i have read. it compiles fine but wont start up my motordriver everything else works great te ping ans sweep do exactley what  want them to do. but no motors :( pls help i am currently trying again and race for class is next week :( i know motordriver works i can get it to work on its own and with the sweep and ping and respond to the ping but would like to have the subroutines and the servo dont like not hving the delays between the pings
#include <Servo.h>
const int ping = 8;  //ping sensor pin number
delay(50);
delay(50);
delay(400); //delay 1000ms
delay(5);
delay (400);
delay(5);
delay (400);
delay(5);
delay (400);
          delay(5);
delay (400);
delay(5);
delay(100);
if(inches > 50 )
forward();
if (inches2 < 12)
rightWall(100);
if (inches3 < 12)
leftWall(100);
if (inches < 50 && inches3 > 52)
leftTurn(2000);
if (inches < 50 && inches2 > 52)
rightTurn(2000);
void wall() {
void forward(){
//left motor
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
void rightWall(int duration)
//left motor
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x00;
buff3[3]=0x40;
for(int i=0; i<4; i++){Serial.print(buff3[i], BYTE);}
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
buff2[3]=0x7D;
void leftWall(int duration)
//left motor
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x00;
buff3[3]=0x7F;
for(int i=0; i<4; i++) { Serial.print(buff3[i], BYTE);}
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
buff2[3]=0x7D;
void reverse(int duration)
//left motor
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x01;
buff3[3]=0x45;
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
buff2[3]=0x45;
void leftTurn(int duration)
//left motor
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x00;
buff3[3]=0x45;
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
buff2[3]=0x7D;
void rightTurn(int duration)
//left motor
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x00;
buff3[3]=0x7F;
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
buff2[3]=0x45;
AWOL
Do yourself a favour - shorten your code with a single range function, instead of typing the same code over and over again:
long getRangeInInches (int ping)
long duration = pulseIn(ping, HIGH);
return microsecondsToInches(duration);
With shorter code, it may make it easier for you to see where you are overwriting results.
Do the rest of us a favour by typing ctrl-T in the IDE before posting your code.
AWOL
Humans are really bad at repetition; computers are really good at it.
void forward()
  moveMotor (0, 0x7F);
  moveMotor (2, 0x7E);
  moveMotor (0, 0x40);
  moveMotor (2, 0x7D);
  moveMotor (1, 0x45);
  moveMotor (3, 0x45);
  moveMotor (0, 0x45);
  moveMotor (2, 0x45);
void moveMotor (unsigned char motor, unsigned char speed)
  unsigned char buff[4];
  //left motor
  buff[0]=0x80;
  buff[1]=0x00;
  buff[2]=motor;
  buff[3]=speed;
    Serial.print(buff[i], BYTE);
Reducing source size gives bugs fewer dusty corners to hide in.
drab
Hey awol thx for the response ill put that together tonight. I have a working one but its pretty long and repedative. But it works and the race for class is on thursday the 2nd so i really apreciate the help thx again
I
