Topic: Servos Delay (Read 4857 times) previous topic - next topic
christophe31
May 26, 2011, 10:21 pm Last Edit: May 27, 2011, 10:54 pm by christophe31 Reason: 1
hi guys,
  i'm a complete new bee, i've buy an arduino uno to control one servo, i need to control it with a very simple program to move it in the 0° position to the 180°position, wait here for 25seconds, and go back to the 0 position, waiting 25sec and again and again...
   does this little program will do this:
  // Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 10)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 10 degrees
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(20000);                       // waits 20sec for the servo to reach the position
  for(pos = 180; pos>=1; pos-=10)     // goes from 180 degrees to 0 degrees
Your opinion and help will be appreciated.
  best regards
christophe
wildbill
Not quite, no. You need to look at the delays you're using. Hook it up and try it though, it'll quickly become obvious what's wrong.
AWOL
Your description says 25 seconds, the code suggests 20 seconds (though it's in the wrong place).
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
christophe31
#3
May 27, 2011, 10:50 pm Last Edit: May 27, 2011, 10:52 pm by christophe31 Reason: 1
yes , but it's just for example, in fact i'll change this delay with test, the most important it's to have the delay in seconds, and to change it, if needed.
   do you think this code like writting here will do this? (with the 20sec delay).
  myy arduino it's on the way and i'll try the code as soon as receive.
  your opinion will be appreciated.
  may be if someone have one arduino linked with an servos , someone can test this.
  christophe
AWOL
Quote
No, your servo will move extremely slowly, taking six minutes to sweep 180 degrees.
zoomkat
Is something like below what you are looking for?
Code: [Select]
#include <Servo.h>
int a = 10;
int b = 170;
  myservo.write(a); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test"); // so I can keep track of what is loaded
  myservo.write(a);
  Serial.println(a);
  delay(5000);
  myservo.write(b);
  Serial.println(b);
  delay(5000);
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
christophe31
Code: [Select]
#include <Servo.h>
int a = 10;
int b = 170;
  myservo.write(a);
  Serial.println(a);
  delay(5000);
  myservo.write(b);
  Serial.println(b);
  delay(5000);
  oh , in this case it's only the loop who have delay, is it correct?
  in mine i've put the delay in the travel of the arms position.
  if it's that , i understand, and will try this one, and make you one video to show youthe result as soon as i receive the arduino.
  thanks for all your help.
  regards
christophe
tomly
If I understand correct you nedd a loop() like this:
  for(pos = 0; pos <= 180; pos += 10)  // goes from 0 degrees to 180 degrees
    delay(15); //delay so that servo reach new position - depends on step - experiment with speed;
delay(25000); //waits 25sec in 180 deg. position
  for(pos = 180; pos>=0; pos-=10)     // goes from 180 degrees to 0 degrees
delay(25000); //waits 25sec in 0 deg. position
johnwasser
So you want:
Code: [Select]
#include <Servo.h>
Servo myservo;
  myservo.write(0);  // Set initial position
  myservo.write(180);  // "move it [from] the 0° position to the 180°position,"
  delay(25*1000);  // "wait here for 25 seconds,"
  myservo.write(0);  // "and go back to the 0 position, "
  delay(25*1000);  // "waiting 25 sec"
  // "and again and again..."
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
christophe31
hi guy's,
   i've receive tonight my arduino uno, and after 5 min of coding, try the code that you have give to me, and i've found one who work fine like i want :
    goes to one position
    Wait the time i want there
    goes to the original position.
   here the code:
  #include <Servo.h>
  for(pos = 0; pos < 180; pos += 180)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 180°
    delay(28000);                       // waits 28s for the servo to reach the position
  for(pos = 180; pos>=1; pos-=180)     // goes from 180 degrees to 0 degrees
  {                                   // in step on 180°
AWOL
Code: [Select]
Well, that's one(long winded) way of doing it.
Simpler might be
Code: [Select]
    myservo.write(0);
    delay(28000);
    myservo.write(180);
    delay(28000);
christophe31
ok i'll try this one too.
thanks
christophe31
#12
Jun 02, 2011, 10:34 am Last Edit: Jun 02, 2011, 01:28 pm by christophe31 Reason: 1
ok so i've try this simplest code, but now, the servos don't do the loop, in fact it does the code one time , and that's all......
  any idea?
 how to proceed to be sure to erase and empty the memory ? to upload code like new card
edit:
  i've succeed with this code:
  #include <Servo.h>
Servo myservo;
Servo servo_b;  // create servo object to control a servo
  myservo.attach(9);
  servo_b.attach(10);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos<=180; pos += 180)  // goes from 0 degrees to 180 degrees
    delay(22000);                       // waits 28s for the servo to reach the position
  for(pos = 180; pos>=1; pos-= 180)     // goes from 180 degrees to 180 degrees
    delay(100);                       // waits 28s for the servo to reach the position
   don't take care of the servo_b, it'ss for another function, and as you note the second delay ( 100ms), doesn't do anything, the servos goes in up/down position each 22sec,
 christophe
AWOL
Quote
There is no need - any sketch uploaded will overwrite the previous one.
I don't understand why it doesn't loop - the code should be functionally equivalent to the one with loops.
Can you post the entire sketch, please?
jraskell
Quote
   any idea?
Sounds like you put that code in the setup() function instead of the loop() function.  If it was in the loop() function, it would get executed repeatedly.  It's very simple code, so there's really no room for any other explanation.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
