Loading...
Pages: 1 [2]   Go Down
Author Topic: Servos Delay  (Read 1383 times)
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Code:
for(pos = 0; pos<=180; pos += 180)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 180°
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(22000);                       // waits 28s for the servo to reach the position
Is it planned that this should take a total of 3960 seconds (66 minutes) to complete this loop?
And you really should update your comments to actually tell what it is doing, it can be very confusing when the code says one thing, and the comment says something else.
Logged
captain-slow.dk | non contagious!
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
No - read the loop conditions.
22 seconds.
Quote
Can't disagree there.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Quote
22 seconds.
Ah, now I see it... But it makes no sense to use the "for" loop then.
This would do the same, but not confuse as much. When I see a loop, I expect it to do some looping, not only do what is inside once then move on.
Code:
pos = 180;
myservo.write(pos);
delay(22000);
Or maybe make it even shorter and just say.
Code:
myservo.write(180);
delay(22000);
Because the "pos" is set to 180 in the next loop anyways.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
See reply #10  ;-)
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
See reply #10  ;-)
lol yeah... smiley-razz
Another way of doing it, and make the servo move slower, and complete the distance in 21.96 seconds, could be like doing it like this
Code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(int pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    delay(122);                       // waits 122ms for the servo to reach the position
  for(int pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Not even sure whey it needs to wait 22 seconds to get to position... it should take less than 1 second to move from one side to another...
Logged
Offline Offline
Newbie
View Profile
 the servos goes to the position quickly, but he wait 22seconds before come back to the "zero" position.
  and the code work now.
  thanks all for your help.
 next step.... doing the accelerometer linked with the servos..... lol.... not done.....
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
