Loading...
Pages: [1]   Go Down
Author Topic: What's the best way insulate wire?  (Read 396 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
What would you suggest if the way to insulate some soldered wire? I am using tape atm  smiley-confuse
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
I'd consider heat-shrink tubing, though you have to remember to slide it on before you do the soldering!
Here's just one possibility:
http://www.elexp.com/cbl_00hs.htm
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
great thank you
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
It is for a simple circuit with a vibration motor, led & pressure sensor powered by a 9v battery pack.
Would you recommend using a glue gun?
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
I've seen industrial boards covered by a layer of transparent conforming glues to protect it from environments. I wonder if such insulating glue can be used on a glue gun. Sometimes I use Teflon tape for quick fix too. It's nasty when you try to take it off.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
No these conformal coatings are normally applied as a liquid or a spray and can be quite expensive. They have the property that you can "solder through" them to affect a repair.
I use hot melt glue a lot to stop things shorting out. But as KE7GKP pointed out first make a solid mechanical joint, then solder it finally insulate it.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Again it might be useful to know what kind of wire you are using? Uninsulated wire is pretty hard to come across by accident. Bus wire is the only example that comes to mind that is truly uninsulated.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
