Loading...
Pages: [1]   Go Down
Author Topic: Unable to see arduino using Debian Squeeze  (Read 631 times)
Offline Offline
Newbie
View Profile
I'm using Debian Squeeze and an Arduino Uno. I have installed the IDE version 0022 and I connect the Uno to my PC using my printer cable (so I am confident that the USB connection works), but the IDE can often only see /dev/ttys0. Sometimes it can see /dev/ACM0, but not always. However, even when I can select that port, I cannot upload a sketch - I always get an error message:
I can see that the necessary USB port exists:
 ls /dev/tty*
<snip>...  /dev/ttyACM0 /dev/tty13....  <snip>
but the IDE usually doesn't seem to be able to see it. Sometimes though I can select the ACM0 port in the iDE, but that still doesn't solve the uploading problem.
Does any one have any guidance on what I must do to fix this?
TIA
Logged
Offline Offline
Newbie
View Profile
what is the output of dmesg when you plug your uno in?
Logged
Offline Offline
Newbie
View Profile
Here it is:
[  302.608028] usb 3-1: new full speed USB device using uhci_hcd and address 2
[  302.806164] usb 3-1: New USB device found, idVendor=2341, idProduct=0001
[  302.806171] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[  302.806175] usb 3-1: Product: Arduino Uno
[  302.806178] usb 3-1: Manufacturer: Arduino (www.arduino.cc)
[  302.806181] usb 3-1: SerialNumber: 64932343738351C09091
[  302.807647] usb 3-1: configuration #1 chosen from 1 choice
[  302.887670] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
[  302.890641] usbcore: registered new interface driver cdc_acm
[  302.891677] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
At this point I can 'see' ttyACM0 in the IDE, but as soon as I attempt to upload a sketch it disappears from the IDE, leaving ttyS0 as the only serial port, which doesn't work.
TIA
Logged
Pages: [1]   Go Up
Print
Jump to:
