Topic: Need help in processing !! (Read 1 time) previous topic - next topic
AlienArea51
Hi
How can i do , Arduino send value to processing and after recieve this value on Processing ,I shall wish to make this :
Code: [Select]
int val=port.read();
String[] valsondes =Integer.toString(val);
saveStrings("http://william.favard.perso.sfr.fr/ALIENAREA51/sondesT.txt", valsondes);
But that does not work, because " cannot convert from String to String[] "
Please how to make ???
Thanks to the advance
P.S: sorry for my English
William
The truth is elsewhere !!
johnwasser
Have you tried this?
Code: [Select]
  String valsondes =Integer.toString(val);
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
AlienArea51
HI and thank
YES , that does not work ,because :
saveStrings(String,String[] ).
William
PaulS
Quote
What exactly does saveStrings do with the second argument? Perhaps you need to create an array of String objects as well as the String created from the int, and store the one String in the String array, and pass that array to saveStrings.
johnwasser
If you want to initialize an array of strings it would looks something like this:
Code: [Select]
  String valsondes[] = {Integer.toString(val)};
If that's all you do with 'val' you don't really need it:
Code: [Select]
  String valsondes[] = {Integer.toString(port.read())};
AlienArea51
Hi
Thanks to all.
That does not still work  :~
Processing answers:  cannot convert string to string[]
PaulS
Quote
Time to post YOUR code.
johnwasser
I guess I must have the syntax for initializing an element of an object array wrong.  Try initializing in a separate step.
Code: [Select]
  String valsondes[1];
 valsondes[0] = Integer.toString(val);
AlienArea51
Hi
@johnwasser
Sorry, but that does not still work =(
It's not serious, I shall find another solution.
@paulS
The code was put in the beginning of the post,The rest of the code has no influence  ,It is a question of reading a variable coming from the port of communication ( Xbee).
Thanks to you, to have answered,
cordially William
PaulS
Quote
No. A snippet of code was posted. You have been given many suggestions since then, and asked to post more code. You haven't done so. Presumably, you are making changes to incorporate the suggestion, but they are not working.
Answer the questions and post some code so we can see that you have implemented the suggestions correctly.
Otherwise, quit complaining that "it still doesn't work".
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
