Topic: MOSFET for high speed PWM (Read 4766 times) previous topic - next topic
RuggedCircuits
Meh...that's a 1.5 ohm MOSFET. That's pretty high and will get very warm if carrying ~1A of current.
If you're constrained by a particular supplier, let us know what that is and perhaps we can work around this constraint.
The DIN Rail Mount kit for Arduino: quickly attach your Arduino to standard DIN rail
daveg360
I guess with such a short pulse, using multiple parallel mosfets (that are available), isn't an option?
TomS
Darn, I didn't check the resistance you are right.
I am currently living in Germany and will be ordering from voelkner.de in the next few days.
If I could find a driver and mosfet there that would be great.
Unfortunately their assortment isn't too big, so conrad.de might be the alternative.
They both seem to carry a lot of transistors by "International Rectifier" so I'm now trying to find suitable mosfet from them, but no luck so far.
Dave:
I have no idea since I haven't worked with mosfets so far, but wouldn't parallel mosfets actually increase the total gate capacitance and thus be even slower?!
daveg360
I was thinking in terms of charging say 4 in parallel would be quicker than 1 large gate.  Finding suitable mosfets for the job isn't trivial though  :~
In terms of mosfet top trumps - the item that RuggedCircuits posted (STP27N3LH5) is pretty hard to beat....  I'm currently trying to design an utterly indestructible H Bridge (it's taking me forever).  I think I might use a number of those.
MarkT
Quote
You are right, if you want fast, well-defined pulses you will want a combination of a low gate capacitance MOSFET and high-current MOSFET driver, like a Microchip TC4426A.
Not necessarily, for an amp or so a MOSFET driver chip is sufficient in itself (and much faster) - the MIC4422 for instance will drive several amps and has logic level input.  For a low-duty cycle application this will do without further boosting (not much power dissipation required).
TomS
That's a very interesting idea Mark, thanks for pointing it out!
