Topic: Simple Transistor Question (Read 967 times) previous topic - next topic
aKiwi
Hello fellow peeps!
When i use -> digital(pin, HIGH) for the base pin on my little transistor (2N3904) i get everything working.
But if i use the 5v pin from Ardunio it doesn't..
What basic principle am i missing here?
/slightly confused
jackrae
Do you have a base current limiting resistor (say 4k7) in the transistor base connection.  If not then the base junction is causing a (almost) dead short across the supply line.  Why would you want to connect the base to the 5volt line ?
markbee
in fact you almost always need a base resistor. for the common npn-transistors like 2n3904 or bc547 etc. it's quite easy to calculate if you want to use the transistor as a switch:
Rbase = Uvcc-Ube/ Ibase => Rbase = (5 volt-0,7volt)/0,002A = 2150 ohms.
So if you want to drive the transistors base with 2 mA you need a resistor to the base of about 2k2 ohms.
markbee
XBee blog: http://lookmanowire.blogspot.com/
aKiwi
Thanks for the replies.
My basic newb thinking was that iirc, digitalwrite at high was = to 5v, so with some quick proof of concept testing i thought it should do the same thing.
Clearly i have much to learn. ;)
Thanks.
James C4S
Quote
The difference wasn't explicitly stated:  the I/O pin limited the current to the transistor, the 5V supply did not.  Neither is a good thing, because the I/O pins are not designed to be current limiters.  As already stated, you should always have a current limiting resistor connected to the base of the transistor (in cases where you are using it as a switch.)
With a current limiting resistor in series with the base, the I/O pin and 5V supply will work the same for turning on the transistor.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
aKiwi
Thanks for that James.
Have used this transistor with another 9v circuit, running pwm with no resistor.
Duly noted, if using as a switch - need resistor. (With calc used above)
Used a 1R2 (instead of 2150 ohms) resistor for a test and it held it open and then faded out. So i think i need to do some googling to further my knowledge.
Thanks for the help.
Grumpy_Mike
Quote
In this context a 1R2 resistor is just like no resistor at all. Unless you mean a 1K2.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
