Topic: [SOLVED] Multiple Components Need 5V power (noob question) (Read 2358 times) previous topic - next topic
fcampbell
May 28, 2011, 07:08 pm Last Edit: May 28, 2011, 08:01 pm by fcampbell Reason: 1
Hi there everybody,
I need to use a Piezo buzzer, servo and a keypad.
All of these require the same power pins. What would I do in order to get that power to multiple components.
Would I use a breadboard and connect there or something else?
Thank you for all the help!
(I am a noob, so...)
Grumpy_Mike
Wire them all to the same pin.
Having said that, running a servo of the 5V regulated pin sometimes causes random resets. It depends on how much current it takes and how electrically noisy it is.
fcampbell
Thank you,
But what do you mean wire them all to the same pin?
I'm not much of an electrician/hardware programmer ( I do software programming :P (mainly) )
Grumpy_Mike
Quote
If you have three components that all need 5V and one pin that has 5V on it, then wire all three components to the same 5V pin.
(or else stick to software  :)  )
fcampbell
Grumpy_Mike
fcampbell
Thank you Grumpy_Mike
I just realized the +/- on the breadboard.
[Solved]
elandd2011
Don't foget use small capacitor from 5v to gnd if connection cable are longer  than 15 cm for reduce noise
