Topic: Matrix Keypad - Optimisation (Read 15363 times) previous topic - next topic
robtillaart
case "a":  ==> case 'a':
you must use single quotes, otherwise it is a string and the case will use the address of the string or so.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Deep_C
#46
Dec 02, 2010, 08:36 pm Last Edit: Dec 02, 2010, 08:47 pm by Deep_C Reason: 1
single quotes worked, thanks
I still don't get the fuction of this code:
Code: [Select]
 int k = kbValue(keyboardValue);   // maps the value of the key being pressed "keypressed" i.e. 0-9
 Serial.println(k);                // print the value back to the Serial view window on your PC
// interpret the keyboard routine
int kbValue(int kbv)
robtillaart
in plain English: kbValue() will do a lookup of keyboardValue (the parameter passed) and returns a value 0..16 to indicate the keypressed. This return value is assigned to the var k.
The names are a bit misleading here. Better names could be
- int rawKeyPressed = analogread(A0);
- int key = ConvertRawToKey(rawKeyPressed);
- switch(key)
etc
Rob Tillaart
CrossRoads
try just single quotes, not double. Think you have to decide on one other  - is keypressed going to by type char, or type int (or byte)?
Deep_C
yeah the single quotes worked on case
rob- thanks for the disambiguation
-carl
