Topic: Troubles with Java and Arduino: Communication. (Read 1 time) previous topic - next topic
Inix88
Hi all. I'm trying to communicate a Java program with my arduino uno for send orders to the board and read the data sended from it on Java. I'm using the RXTX library ( http://rxtx.qbang.org/wiki/index.php/Download ), version for linux x86_64.
The problem is when i run this example program for learn:
Code: [Select]
package program;
//Main program class
public class Program
//Declares the Arduino object field
public static ArduinoComm myArduino;
  //Main method
  public static void main(String args[])
     myArduino = new ArduinoComm();
     myArduino.start("/dev/ttyACM0",115200);
     myArduino.closeSerialPort();
Code: [Select]
package program;
//This class:
// - Starts up the communication with the Arduino.
// - Reads the data coming in from the Arduino and
//   converts that data in to a useful form.
// - Closes communication with the Arduino.
//Code builds upon this great example:
//http://www.csc.kth.se/utbildning/kth/kurser/DH2400/interak06/SerialWork.java
//The addition being the conversion from incoming characters to numbers.
//Load Libraries
import java.io.*;
import java.util.TooManyListenersException;
//Load RXTX Library
import gnu.io.*;
class ArduinoComm implements SerialPortEventListener
  //Used to in the process of converting the read in characters-
  //-first in to a string and then into a number.
  String rawStr="";
  //Declare serial port variable
  SerialPort mySerialPort;
  //Declare input steam
  InputStream in;
  boolean stop=false;
  public void start(String portName,int baudRate)
     stop=false;
     try
        //Finds and opens the port
        CommPortIdentifier portId = CommPortIdentifier.getPortIdentifier(portName);
        mySerialPort = (SerialPort)portId.open("my_java_serial" + portName, 2000);
        System.out.println("Serial port found and opened");
        //configure the port
        try
           mySerialPort.setSerialPortParams(baudRate,
           SerialPort.DATABITS_8,
           SerialPort.STOPBITS_1,
           SerialPort.PARITY_NONE);
           System.out.println("Serial port params set: "+baudRate);
        catch (UnsupportedCommOperationException e)
           System.out.println("Probably an unsupported Speed");
        //establish stream for reading from the port
        try
           in = mySerialPort.getInputStream();
        catch (IOException e)
           System.out.println("couldn't get streams");
        // we could read from "in" in a separate thread, but the API gives us events
        try
           mySerialPort.addEventListener(this);
           mySerialPort.notifyOnDataAvailable(true);
           System.out.println("Event listener added");
        catch (TooManyListenersException e)
           System.out.println("couldn't add listener");
     catch (Exception e)
        System.out.println("Port in Use: "+e);
  //Used to close the serial port
  public void closeSerialPort()
     try
        in.close();
        stop=true;
        mySerialPort.close();
        System.out.println("Serial port closed");
     catch (Exception e)
     System.out.println(e);
  //Reads the incoming data packets from Arduino.
  public void serialEvent(SerialPortEvent event)
     //Reads in data while data is available
     while (event.getEventType()== SerialPortEvent.DATA_AVAILABLE && stop==false)
        try
           //Read in the available character
           char ch = (char)in.read();
           //If the read character is a letter this means that we have found an identifier.
           if (Character.isLetter(ch)==true && rawStr!="")
              //Convert the string containing the characters accumulated since the last identifier into a double.
              double value = Double.parseDouble(rawStr);
              if (ch=='A')
                 System.out.println("Value A is: "+value);
              if (ch=='B')
                 System.out.println("Value B is: "+value);
              //Reset rawStr ready for the next reading
              rawStr = ("");
              //Add incoming characters to a string.
              //Only add characters to the string if they are digits.
              //When the arduino starts up the first characters it sends through are S-t-a-r-t-
              //and so to avoid adding these characters we only add characters if they are digits.
              if (Character.isDigit(ch))
                 rawStr = ( rawStr + Character.toString(ch));
                 //Get the decimal point
                 if (ch=='.')
                    System.out.print(ch);
i can't connect to the board and the IDE show me :
Code: [Select]
run:
Port in Use: gnu.io.NoSuchPortException
java.lang.NullPointerException
BUILD SUCCESSFUL (total time: 1 second)
However, when i start the object "myArduino" with "/dev/ttyS0" (a serial port from the OS) the program run ok and it can connect to the port. This is my output of /dev/tty :
Code: [Select]
crw-rw---- 1 root dialout 166,  0 2011-05-29 17:58 /dev/ttyACM0
crw-rw---- 1 root dialout   4, 64 2011-05-29 17:48 /dev/ttyS0
Anyone who knows where the problem is?
Thaks all.
