Author Topic: Troubleshooting - Better way?  (Read 243 times)
Houston Area
I have two Arduino's connected together using  I2C (SDA & SCL) to pass data from one to the other. It's not working correctly.
I added serial output throughout the program so I can see what is going on with the variables and other data.
I have to plug in the USB in one Arduino to view the serial and then move it to the other to view that serial data which cause the program to pause etc...
I have tried two USB cables which saves me the trouble switching cables but I have to change the serial port.
I like to view both sketches running at the same time.
Is there a method or technique that I can use to view the serial output from both Arduino's at the same time or is this the best way.
Thanks
Randy
Portugal
Use hyperterminal or any other terminal and just open two instances, one with each port.
Netherlands
Online Online
View one Arduino with the IDE serial monitor and the other with a terminal program like putty.exe
Furthermore, read this one? - http://www.arduino.cc/en/Tutorial/MasterReader - ?
Rob Tillaart
Worcester, MA
If you want,post your code and maybe we can help.
I2C GPS Shield
Checkout my Open Source GPS Tracker on Kickstarter
Houston Area
Thanks WayneIF
I will try and troubleshoot first. Part of the learning curve but I think it may be an issue with interrupts and calling a function to send a byte in the event procedure...not sure. Timming? Perhaps not an issues.
