Loading...
Pages: [1]   Go Down
Author Topic: Converting an int into separate bytes (segment display)  (Read 468 times)
New Zealand
Offline Offline
Newbie
Arduino rocks
View Profile
Hey there.
Am using a 4 digit, 7seg display with a 74HC595 bitshifter.
I have seen examples of where people have used a bitshifter for each digit.
Which seems overkill.
I have it displaying random numbers without any issues of flickering.
However i want to use a analogRead varible and display that.
Anyone have any tips on how to approach this?
This is a common anode display, so i am sending the bits to the shifter then setting pin high and then low on the anode (with a small delay) before moving to the next digit.
so some how getting an int 1024 to be a char 1, char 0, char 2, char 4?
Any help would be appreciated.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Try this? It should split 1024 into {'1', '0', '2', '4'}, but it's not tested whatsoever.
Code:
char digits[4];
int val = analogRead(0);
for (uint8_t i = 0; i < 4; i++) {
  digits[i] = (val / (10 * (3 - i))) + '0';
  val %= 10 * (3 - i);
Logged
New Zealand
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks, when i print out the binary with your code it seems to be doing what i want.
The way my code works is it uses this character set
Code:
const byte ledCharSet[10] =
  // Binary Digits
  B01111110, B00110000, B01101101, B01111001, // 0123
  B00110011, B01011011, B01011111, B01110000, // 4567
  B01111111, B01111011       // 89
hence if i want a '3' to display i call bitShift(ledCharSet[3])
So i am having trouble linking your digits
  • to this ledCharSet.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Oh.  You implied you wanted characters - just remove the + '0' from the digits line - that converts it from the number 0 to the character '0', and you need the number to use as an index.
Logged
New Zealand
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for your help Aeturnalis,
I managed to get it sorted just before your reply.
Code:
int digits[4] ;
  for (int i = 3; i >= 0; i--) {
    digits[i] = val % 10;
    val /= 10;
then used that to access the array of digits.
I tried yours (without the zero) for test sake, but it makes the digits go into all sorts of weird characters.
(Im assuming it is due to passing a char instead of a byte to my shift function -> might try out some bitwise operators to get it working.
Thanks again
« Last Edit: May 30, 2011, 03:04:46 am by aKiwi » Logged
Pages: [1]   Go Up
Print
Jump to:
