Topic: Kingbright SA23-12SRWA (Read 3750 times) previous topic - next topic
CrossRoads
Aug 07, 2011, 04:25 am Last Edit: Aug 07, 2011, 04:34 am by CrossRoads Reason: 1
Anyone have an Eagle library for this part?
I really struggle creating  new ones.
http://www.kingbrightusa.com/images/catalog/SPEC/SA23-12SRWA.pdf
Thanks!
mmcp42
#1
Aug 07, 2011, 11:28 am Last Edit: Aug 07, 2011, 02:34 pm by mmcp42 Reason: 1
here's one I put together for you
it's functional but not pretty
pretty follows shortly
(I think I got the pins right!)
slightly prettier
(big beast tho' ain't it!)
there are only 10 types of people
them that understands binary
and them that doesn't
CrossRoads
Mike,
Thanks very much.  Can you send that to me directly please? robert@crossroadsfencing.com
Massimo made me a moderater yesterday, and now I cannot see any attachments. I've asked him to fix that, or unmake me a moderator.  Its like having blinders on all of a sudden.
Yes, it is a big part, expensive too. Kinda funny - won't take a lot of room on a schematic, but will on a board ;)
mmcp42
CrossRoads
Cool - thanks very much! Gonna go play for a while 8)
embeddedUser
Hi
I am planning to connect Arduino to KingBrights 16 Segment Alphanumeric display.
I am planning to use Maxim's 6955 LED driver IC to driver the LEDs.
Could you suggest me the software libraries for this or any other driver which can connect
my Arduino uno to the LEDs.
Thanks
CrossRoads
So you're going to wire it up like on page 37 or thereabouts?
http://datasheets.maxim-ic.com/en/ds/MAX6955.pdf
I am not aware of any library's (did you search the Playground?),
but as its just an I2C interface, where you send some set-up commands, and then send a command for the data you want displayed from Table 8 on page 21,
you could send over the data you want displayed using Wire.write commands, pull it from an array.
http://arduino.cc/en/Reference/Wire
Wire.write( display [ x ] );  // where x is the element from the array you want displayed
For example,
display[1] might contain 0x00000001 for the digit 1,
display[2] might contain 0x00000010 for the digit 2
etc for 3,4,5,6,7,8,9,
then 0x00001010 for A, etc for B,C,D,E,F,
then other letters/characters as you need.
The key is reading the datasheet and getting all the needed commands sent during void setup() so the part knows how its operating.
BhanuTejaJ
#7
Mar 21, 2016, 10:55 am Last Edit: Mar 24, 2016, 02:53 pm by BhanuTejaJ
Thanks for the library... Thanks a lot <3 !
Update:
I Slightly updated the library for the part, https://www.kingbrightusa.com/images/catalog/spec/SA23-11SRWA.pdf
Eagle Foot Print:  Link (Click the Download button in Drive. Sry, I couldn't find the way to upload it directly)
Please let me know if any corrections needed :)
