Topic: (Noob) Servo question, TowerPro SG-5010 won't move. (Read 2101 times) previous topic - next topic
Scatman
Hi!
I'm new to all this and I have a question about my TowerPro SG-5010 servo.
With this code I'm able to move a micro servo by rotating a pot.
But when i swap the micro servo for my TowerPro (a lot bigger) it won't work.
Is this a power related problem? What do i need to do to make use of my 5010?
Thank you very much!
#include <Servo.h>
Servo myservo;
int sensorPin = 0;
int sensorValue  = 0;
  myservo.attach(9);
void loop(){
  sensorValue = analogRead(sensorPin);
  int place = map(sensorValue, 0, 1023, 180, 0);
  myservo.write(place);
robtillaart
Maybe the powertoy draws too much current for the Arduino to handle, try using a separate voltage supply.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Scatman
Just tried it with a another 5010, and it works. Probably a faulty servo? Or can the difference in current between servos be that big?
robtillaart
Quote
1) Possible
2) yes
Do you have a multimeter to see how much current is drawn?
And yes an Arduino cannot deliver so much (from head 50mA per pin max) where a servo can easily draw 4 times as much .....
Rob Tillaart
