Topic: HOW TO: 8x16 Display using 128x64 LCD with ST7920 driver on SPI (Read 6845 times) previous topic - next topic
drsandyrae
I have developed a way to easily display 8 lines by 16 characters on a 128x64 Graphic LCD using a ST7920 driver chip on a SPI bus. This display is widely bought for it's graphic display capabilities, however, this device is only capable of displaying a 4x16 English font as a default display mode. (see sample sketch available from DFRobot and others.) Many developers have wished for more character display capability. This program allows the use of this device as a character display eliminating the expense of a dedicated character display.
This program requires a DFRobot DFR0091 SPI LCD module or equivalent.
This program requires the following devices:
  • A SPI enabled 128x64 LCD graphic display using the ST7920 driver chip*, such as the DFRobot DFR0091 SPI LCD module
  • An EEPROM module on I2C at 0x55*, such as the DFRobot DFR0117 EEPROM module
*see sketch comments for additional information
You will need to install two (2) sketches:
  • Install "Write_EEPROM_Data.pde" into your Arduino program directory.
  • Copy "asciiFont.h" to the Write_EEPROM_Data directory created above.
  • Install "LCD_Test.pde" into your Arduino program directory.
After you have installed the above sketches:
  • Using Arduino IDE 022, load and run Write_EEPROM_Data to write font data to EEPROM.
  • Using Arduino IDE 022, load and run LCD_Test.
*** This software is free public domain. It is offered AS-IS, no warranty or guarantee of any kind, USE AT YOUR OWN RISK. ***
Good Luck,
Dr. Sandy Teller
MRL Robotics
liuzengqiang
This is a more appropriate place to post your product:
http://arduino.cc/forum/index.php/board,25.0.html
Since there are 128 pixels in a row and regular 7*5 dot matrix characters use 6 pixels wide, you can go up to 21 characters in a row, can't you? So why the 16?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
drsandyrae
liudr,
Unfortunately the arduino ide does not allow bit arrays. This would allow for individual pixel placement. Since we are restricted by the ST7920 driver chip all write operations require 8 bits of data, a byte, hence the use of a 8x8 font. Please download and view the pde file for more information. The sketch is fully commented.
Please note that this was written to accommodate the arduino ide without resorting to avr code.
This is not a product, only software to utilize a specific LCD display with a ST7920 driver chip.
Dr. Sandy Teller
MRL Robotics
liuzengqiang
If you have some videos, you can post on the exhibition forum. A few video clips will motivate people to go get the hardware for a try. I though you made those displays  :smiley-red:
kdawson
Hi There,
The ability to do 8 (or at least 6) lines of text on this display was just what I was after. Where are the referenced files though?
Am I missing something?
Regards,
Karl
olikraus
Hi
I just want to mention, that u8glib supports the ST7920 and you can use any of the fonts from here: http://code.google.com/p/u8glib/wiki/fontsize.
Of course you could have the 21 chars per row...
Oliver
kdawson
Thanks Oliver, that was exactly what I was looking for! It works great; much appreciated   :D
floresta
Quote
Could you explain this more fully?
Don
