Author Topic: adding a time interval to a PIR sensor  (Read 423 times)
Hi all,
Some of you may remember I wrote in a while ago about activating a 35000V stun gun with a PIR sensor using an UNO.  I've got it all working, but can't seem to drop the amount of time the stun gun fires below 4 seconds.  Does anyone have any suggestions as to how to go about doing this?
Thanks
Motion detected= LED on for 1sec, 2sec, 3sec.......etc.....
no motion LED off
UK
Online Online
Well, we can't see your code or any details of your project, so suggestions would be "post it".
Red Sea, Saudi Arabia
..On The Red Sea
If the sensor is like this one:
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=173
That little orange pot is a minimum time when fully Counter Clockwise.  But that may still be too long??
So, in code, wait for the sensor to come on, fire the Whatever for however long you want, then wait for the sensor to go OFF, then repeat??
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
I was offered this suggestion in the past and used this to get everything up and running
http://www.ladyada.net/learn/sensors/pir.html
The only alteration I made that enables some control over the gun firing time is an added  delay(10); as seen below (this allows for the 4 sec. firing time)
 * PIR sensor tester
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
void loop(){
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin, HIGH); // turn LED ON
    delay (10);
    if (pirState == LOW) {
      // we have just turned on
      Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH;
      delay (10);
    digitalWrite(ledPin, LOW); // turn LED OFF
    if (pirState == HIGH){
      // we have just turned of
      Serial.println("Motion ended!");
      pirState = LOW;
Does the PIR sensor put out too much power to drop the time?
is that a silly question?  I'm a novice at best when tackling these issues.
Thanks all
UK
Online Online
It could be - what does it mean?
I believe the PIR has a default refractory period which results in the minimum 4 second firing time for the gun.  How can I alter that?
Netherlands
A naughty mind is a joy forever.
I guess what you need is explained in the ladyada article. (Changing pulse time and timeout length)
The Pir sensor works with two intervals, the time the output stays high after detection and the time it waits before it starts detecting again. Those are controlled by capacitor and resistor. By changing the values of the capacitor/resistor of the specific interval you can make it longer/shorter.
