Topic: Starter Arduino and Logo Sensors/Motors (Read 943 times) previous topic - next topic
slpefanis
Hi All
First time posting on the forums, and just got my first board. Now i am sure this has been asked countless time before, but having issues digging up the information
I have lots of lego at home and have the Mindstorm sets (first one and NXT). I have a whole lot of motors that will work with the first set.
Instead of buying a whole new set of motors/sensors i thought it would be worth getting these to work for me. I was wondering if anyone has some simple, easy to understand insructions on how i can go about getting them to work?
I have the Arduino and also got the Electronic Brick Starter kit. I recently bought a Motor Shield L298N as i thought that would help.
Would appreciate any wiring, instruction and guidance on where to go.
Thanks a lot
Stephen
TerryKing
Hi Stephen,
I have used the Mindstorms motors with H-bridge like your L298.. They are run from 9V in the original RCX h-bridges. You can run them from 9V and also use that to run the Arduino through the external power jack. 6 AA rechargeables might be good.
Someone has a complete analysis of the Mindstorms motors on the web; http://www.philohome.com/motors/motorcomp.htm
The NXT motors, I believe are run by signals from the controller... I2C?? Anyone??  More info here: http://www.philohome.com/nxtmotor/nxtmotor.htm
Let us know how you are doing with this....
slpefanis
Thanks for that link Terry, it shows me a bit about the Motors i have. I got the 43362 and the NXT and also some of the older 2838 ones at home so quite a collection :)
I think i have the 43362 motor's sussed on that shield, but that was just trial and error as the documentation for what the "switches" on it does are a little sparse.  (would i say be able to run a few 12V motor's through that board with an external 12v power supply"?)
With the NXT I read they have an angle sensor which i assume means it can be a lot more accurate movements, i assume that it will then have an input (power) and output (sensor value)?
The next thing is some of the sensors i have for the lego would be good to use as there is temperature, distance and LED which are always fun...
