Loading...
Pages: [1]   Go Down
Author Topic: help hooking up a CD4066 CD4066BE  (Read 372 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
anyone know how to fire the switches on the CD4066BE with arduino.
should i connect an arduino digital pin to the control pin on the the CD4066BE?
maybe use a resistor with it?
sorry - probably a somewhat newbish question!  smiley-grin
« Last Edit: December 04, 2010, 02:26:46 pm by animalstyle » Logged
CT, USA
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
Assuming that you have checked the datasheet... anyway, like any digital switches, the switch's state is controlled by a control pin. For instance, for channel A, asserting pin 13 to high will connect pin 1 and 2. So, basically, you can use Arduino's digital output pins to control the control pins of the switch.
« Last Edit: December 04, 2010, 03:13:23 pm by AlphaZeta » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
i just wanted to know what the circuit would look like and if i'd need a resistor - can't really tell from the datasheet.  does anyone know this?
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Where? What are you doing?
Logic to logic connections do not need a resistor. So you can connect the arduino directly to the switch control pins.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
thanks for the responses!
Logged
Pages: [1]   Go Up
Print
Jump to:
