Topic: Coding Issues - Serial Communication (Read 1 time) previous topic - next topic
Yogurt
Currently I'm having some troubles with serial communication between two arduinos. I can send and receive the data however the receiving end seems to be getting a lot of interference since the motors are turning when they shouldn't be.
Transmitter.
Code: [Select]
#include <PS2X_lib.h>  //for v1.6
PS2X ps2x; // create PS2 Controller Class
// Arrays, 0 = Left, 1 = Right, 2 = Vertical
int ledPin = 3;
int error = 0;
int data[] = {
  0, 0};
int pwm[] = {
  0, 0, 0};
int dir[] = {
  0, 0, 0};
byte type = 0;
int sync = 0xAA;
int led1 = 0xBB;
int led2 = 0xCC;
void setup(){
  pinMode(ledPin, OUTPUT);
  error = ps2x.config_gamepad(13,10,11,12, true, true);   //setup pins and settings:  GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
void loop(){
  ps2x.read_gamepad();
  data[0] = (ps2x.Analog(PSS_LY));
  data[1] = (ps2x.Analog(PSS_RY));
  for(int index = 0; index < 2; index++){
    if(data[index] <= 104){
      pwm[index] = map(data[index], 104, 0, 0, 255);
      dir[index] = 1;
    else if(data[index] >= 150){
      pwm[index] = map(data[index], 150, 255, 0, 255);
      dir[index] = 0;
    else{
      pwm[index] = 0;
      dir[index] = 0;
  if(ps2x.Button(PSB_L2)){
    pwm[2] = 255;
    dir[2] = 0;
  else if(ps2x.Button(PSB_R2)){
    pwm[2] = 255;
    dir[2] = 1;
  else{
    pwm[2] = 0;
    dir[2] = 0;
  for(int index = 0; index < 3; index++){
    Serial.write(sync);
    Serial.write(index);
    Serial.write(pwm[index]);
    Serial.write(dir[index]);
      delay(50);
  if(Serial.available() > 0 && Serial.read() == led1)
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
Receive:
Code: [Select]
int inData[4];  // Allocate some space for the Bytes
int index;
int pwm;
int dir;
int motorPin[] = {
  6, 9, 10, 11};
int dirPin[] = {
  2, 3, 4, 5};
int sync = 0xAA;
int led1 = 0xBB;
int led2 = 0xCC;
// 0 = left, 1 = right, 2 = vertical
void setup(){
  for (int x = 0; x < 4; x++){
    pinMode(motorPin[x], OUTPUT);
    pinMode(dirPin[x], OUTPUT);
boolean recieve(){
  if(Serial.available() > 0 && Serial.read() == sync){ //If there is a Serial message waiting and the Serial is sync, then proceed
    delay(2);
    index = Serial.read(); // index
    delay(2);
    pwm = Serial.read(); // pwm value
    delay(2);
    dir = Serial.read(); // dir value
    delay(2); // YOU NEED DELAY, delay prevents garbled messages. (saves you from headaches)
    return true;
    return false;
  if (recieve()){
    Serial.print(led1, BYTE);
    if(dir == 1)
      dir = HIGH;
    else if(dir == 0)
      dir = LOW;
    switch(index){
    case 0:
      analogWrite(motorPin[0], pwm);
      digitalWrite(dirPin[0], dir);
    case 1:
      analogWrite(motorPin[1], pwm);
      digitalWrite(dirPin[1], dir);
    case 2:
      analogWrite(motorPin[2], pwm);
      analogWrite(motorPin[3], pwm);
      digitalWrite(dirPin[2], dir);
      digitalWrite(dirPin[3], dir);
    Serial.print(led2, BYTE);
Please help!
PaulS
Code: [Select]
    delay(2);
    delay(2);
    delay(2);
The last comment is wrong. No, make that WRONG!!!!
The delay is not saving you headaches. It is causing you headaches.
You are testing that there is at least one character available to read, and then reading all 4 of them. The receive() function should test that Serial.available() returned a value greater than or equal to 4 before doing any reading. Then you get get rid of the delays that are masking the problem sometimes.
Some capacitors on your motors, to cut down on noise, might be needed, too.
AgeingHippy
I have not looked at your code, but personally I have found using a separate power source for your motors (relative to the power-source for your micro controller) seems to improve spurious movement on the motors. Does for me anyway. NB - I am a noob and don't know what I am doing...
