Loading...
Pages: [1]   Go Down
Author Topic: Pyroelectric Infrared Detector LMI 878  (Read 457 times)
California
Offline Offline
Sr. Member
View Profile
WWW
http://www.alldatasheet.com/datasheet-pdf/pdf/14906/PERKINELMER/LHI878.html
I got this thing to sense motion. But I can't completely tell how to use it. It seems one pin gets power, another ground, and another is parallel to the power and creates variances in the source voltage to be measured. But I cant tell which pins for which and how exactly to detect motion with the arduino. I figure I use a resistor to get the voltage down to around 2.5v so that the analog in can detect higher and lower voltages. But thats just a guess.
Thanks
Logged
Offline Offline
Jr. Member
View Profile
O k
 look
ground to arduino ground
D trough 10 k ohms to 5 volt  in the arduino
S to the any analogue pin to the arduino
Logged
California
Offline Offline
Sr. Member
View Profile
WWW
Im not really getting any coherent response. Should I be using something else between the arduino and the PIR or should this work?
Logged
Pages: [1]   Go Up
Print
Jump to:
