Loading...
Pages: 1 2 [3]   Go Down
Author Topic: HELP with Infrared emitter + sensor problems  (Read 3683 times)
Sioux Falls
Offline Offline
Jr. Member
View Profile
I just realized I worded my last post poorly, when I say " light was on "... I did not mean IR led, I meant incandescent light only, just to test how much the values change when someone would turn a light switch on or off.  The room was completely dark, then I switch an incandescent light on, then off.  Not ir led, sorry for the confusion if there was any.
Logged
Sioux Falls
Offline Offline
Jr. Member
View Profile
Man this stuff is frustrating.
Ok, I want to set up an IR receiver that will calibrate to the environment... ( check to see how much ir light is in the environment) and then set that as the new zero level, so if the other IR receiver receives a little more ir light than that new zero ( threshold), then an led will turn on.  To test this, I simply have 2 of the exact same infrared receivers hooked up the exact same way with the exact same resistors to analog 0 and 5 on the arduino.  The 2 receivers are not more than 1 inch apart and are at the same level vertically.  The problem is they are receiving vastly different ir values?? why?
here is the code and the resulting values.....
int Calibration;
int Receiver;
  int Receiver = analogRead(A5);
  int Calibration = analogRead(A0);
  Serial.println("Calibration Input = ");
  Serial.println(Calibration);
  Serial.println("Receiver Input = ");
  Serial.println(Receiver);
 here are the values..
Calibration Input =
133
Receiver Input =
359
Calibration Input =
141
Receiver Input =
377...
HOW COULD THEY BE SO DIFFERENT?
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
