Loading...
Pages: [1]   Go Down
Author Topic: T flip flop  (Read 592 times)
UK
Offline Offline
Jr. Member
View Profile
WWW
Hello,
At the moment I'm building a sub-circuit of a larger project. It's an LED status display consisting of 8 LEDs, one is a power indicator which is easy, two are momentary and only turn on when a button is pressed which are also easy. The other five have to latch on or off.
Of those five, three are easy, they're turned on and off by DPDT toggle switches which are normally open but have momentary closed positions either side of the middle position, so I've used S-R latches made from NAND gates for them. However, the last two are controlled by DPST toggles with just an off and momentary on position. I've so far determined that a T flip flop is most likely what I need. If I were to have T held high and use the switch as the clock input, would this suit my needs?
Thanks!
Logged
Offline Offline
Jr. Member
View Profile
with your explanation you are right
so make a test and tell us
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
Beware contact "bounce" in the switch.  You'll probably need a separate debounce circuit and toggle circuit...
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
No, switch-bounce would make that very unreliable (expect zero to hundreds of bounces per operation).  I presume you don't have a microcontroller handling this or you could do everything in software?
You need to add debouncing circuit before the flip-flop clock input - an R/C low-pass filter and a schmidt-trigger gate would do (if the flip-flop has schmidt-trigger clock input, that would be ideal).
Logged
Pages: [1]   Go Up
Print
Jump to:
