Topic: Clock (Read 13586 times) previous topic - next topic
ref110
Hello,
I know that the Arduiono is running with a 16 mhz frequency. I want to connect the Arduino to the DDC 101. This element needs a frequency of 2 mhz. Now my question is, how can I create a 2mhz frequency?
Another possibility would be, that I take the 16 mhz and with ICs I chance this frequency into 2 mhz. But I do not really know where can I get the 16 Mhz pulse.
Thanks for your help!
PaulS
Hz is an abbreviation of Hertz. As a sign of respect to the man, you really should capitalize the H.
Quote
No, it doesn't. It runs at 16 MHz. M is an abbreviation of mega, while m is an an abbreviation of milli. A pendulum might swing at 16 milli-Hertz. The Arduino is a bit faster than that, though.
Quote
Might be good to tell us what a DDC 101 is. It would be even better to provide a link.
Quote
For what? This is pretty slow.
johnwasser
The ATmega168/328 has a clock output pin (CLK0) which will give you a buffered copy of the 16MHz clock when you program the CKOUT fuse.
There are also several counter/timers that can produce programmable signals on output pins.  I think you should be able to program one of those timers to generate a 2 MHz square wave.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
davekw7x
#3
Jun 04, 2011, 01:26 am Last Edit: Jun 04, 2011, 03:35 pm by davekw7x Reason: 1
DDC101...how can I create a 2mhz frequency?...
To create a jitter-free constant frequency like that ADC likes to see, you can use one of the ATmega Output Compare register output pins.  The exact frequency isn't terribly critical, but you want the clock to be as "clean" as possible.  I mean, this is a 20-bit converter for goodness sake!
Understanding the timer registers from the data sheets takes a little (maybe more than a little for some of us) study, but the knowledge will make stuff like this "easy."
To get you started, here's a program that I use to create 2 MHz on Arduino Pin 11 of my Duemilanove.  Experiment with the timer register settings to see some of the things you can do with the simplest timer in its simplest mode.  Larger values of ocr2aval slow the clock down.  Sometimes that makes things quieter.
Code: [Select]
// Use of timer2 to generate a signal for a particular frequency on pin 11
// davekw7x
const int freqOutputPin = 11;   // OC2A output pin for ATmega328 boards
//const int freqOutputPin = 10; // OC2A output for Mega boards
// Constants are computed at compile time
// If you change the prescale value, it affects CS22, CS21, and CS20
// For a given prescale value, the eight-bit number that you
// load into OCR2A determines the frequency according to the
// following formulas:
// With no prescaling, an ocr2val of 3 causes the output pin to
// toggle the value every four CPU clock cycles. That is, the
// period is equal to eight slock cycles.
// With F_CPU = 16 MHz, the result is 2 MHz.
// Note that the prescale value is just for printing; changing it here
// does not change the clock division ratio for the timer!  To change
// the timer prescale division, use different bits for CS22:0 below
const int prescale  = 1;
const int ocr2aval  = 3;
// The following are scaled for convenient printing
// Period in microseconds
const float period    = 2.0 * prescale * (ocr2aval+1) / (F_CPU/1.0e6);
// Frequency in Hz
const float freq      = 1.0e6 / period;
   pinMode(freqOutputPin, OUTPUT);
   // Set Timer 2 CTC mode with no prescaling.  OC2A toggles on compare match
   // WGM22:0 = 010: CTC Mode, toggle OC
   // WGM2 bits 1 and 0 are in TCCR2A,
   // WGM2 bit 2 is in TCCR2B
   // COM2A0 sets OC2A (arduino pin 11 on Uno or Duemilanove) to toggle on compare match
   TCCR2A = ((1 << WGM21) | (1 << COM2A0));
   // Set Timer 2  No prescaling  (i.e. prescale division = 1)
   // CS22:0 = 001: Use CPU clock with no prescaling
   // CS2 bits 2:0 are all in TCCR2B
   TCCR2B = (1 << CS20);
   // Make sure Compare-match register A interrupt for timer2 is disabled
   TIMSK2 = 0;
   // This value determines the output frequency
   OCR2A = ocr2aval;
   Serial.print("Period    = ");
   Serial.print(period);
   Serial.println(" microseconds");
   Serial.print("Frequency = ");
   Serial.print(freq);
   Serial.println(" Hz");
   // Do (almost) anything you want here.  Just don't do analogWrite to
   // pins controlled by Timer 2.  In fact, don't do anything that messes
   // with the registers in Timer 2.
In addition to creating a jitter-free clock, using this method requires no program intervention after the initial setup, so the "good stuff" in your program will not be bothered by anything here.
I recommend a small resistor between the Arduino Pin 11 output and the external device.  I usually use 100 Ohms or so to keep the ringing off of the output clock for short runs.  Don't forget to connect the external device ground to Arduino ground.
Regards,
Dave
ref110
Hello,
thanks for your posts.
The Datasheet of the DDC101 can be found here:
http://www.datasheetcatalog.org/datasheet2/a/0afl0ect5614dah40t143t8gajky.pdf
I´m not really sure if the clock is very solid if I take your advice. What do you think?
The other possibility would be, that I create the 2MHz frequency with FlipFlops (ICs). A friend told me, that that would be better.
Where can I get an 16MHz frequency? Has the Arduino Uno a clock output, or how can I create 16MHz at a pin?#
Thanks for your answers.
davekw7x
#5
Jun 04, 2011, 02:57 pm Last Edit: Jun 04, 2011, 04:28 pm by davekw7x Reason: 1
I´m not really sure if the clock is very solid...
It is as solid and jitter-free as the Arduino clock.
Quote from: ref110
I was not necessarily offering advice.  (I'll save that for the end of this post.)  You asked for a way to get a 2 MHz clock.  I showed how you can generate a 2 MHZ clock using an Arduino timer.
Quote from: ref110
Define "better." Has your friend ever used this ADC?  Where did he/she get the clock?  Has your friend ever created a clock using an Arduino timer for any purpose?  Any purpose at all?
I would be interested in knowing in what way a "clock created with flip-flops" is "better."  I mean, I can see where a clock generated by a properly specified oscillator module rather than one derived from the Arduino clock might have better frequency stability and accuracy and better jitter characteristics, but would this necessarily make it "better" for your application than a clock generated with an Arduino timer???
Quote from: ref110
Ask your friend to show you what he/she has in mind and to cobble one up for you
Quote from: ref110
. Has the Arduino Uno a clock output, or how can I create 16MHz at a pin?
If you are going to use the Arduino clock as a source for your derived 2 MHz output, what's the point?  If you don't need Timer 2 for other things, it costs nothing and requires no external circuitry to create a 2 MHz clock on pin 11.
If you need pin 11 for something else, you can consult the ATmega data sheet to find what other pin can be used with Timer 2.
If you need Timer 2 for something else, you can, maybe, use Timer 1 with either of its Output Compare pins.
If you need both Timer 1 and Timer 2 for other things and/or you need the associated Output Compare pins for something else, or if the Arduino-generated clock is not, for any reason, suitable for you application, then my advice is to buy a 2 MHz oscillator to connect to your ADC.  See Footnote.
Regards,
Dave
Footnote:
Bottom line: Good advice from a good friend may be more valuable than advice from a stranger on the Internet.  My advice is free and is freely given.  It is worth exactly as much as you want it to be worth.
davekw7x: "Over and out."
ref110
ok I have to say sorry. Your solution is better than the other. Because I´m new, I do not really understand which other pins are also possible. I need pin 10 to 13 for SPI. So how can I get 2MHz frequency on another pin than these?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
