Topic: Is the Arduino in trouble (Read 13530 times) previous topic - next topic
oldPGMguy
I see Mircochip has come out with the chipKIT32....its compatiable with arduino shields and has more I/O pins then the ONO,,,should I be worried that this could be the end of the Arduino???????
retrolefty
There is a lot more to the Arduino then just the hardware. I'm certainly not concerned, are you?
Lefty
oldPGMguy
I just did some more reads and saw that some librarys are not ready for it....plus another forum...said the same things you guys did...was just worried that the Arduino would become obsolete...
Bobnova
It all depends on the cost, really.
If it costs less, has more IO, more power, and is totally compatible Arduino's going to have to step it up eventually.
Onions
Quote
451799 Posts in 62639 Topics by 46281 Members.
I would stick to arduino, and I'm sure most of the 46281 forum members will too. I can't see any reason why another clone will stop arduino. It could have the opposite effect, and bring more people to try arduino, after being introduced to microcontrollers through other development boards.
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
liuzengqiang
Quote
Onions.
If half of the first page of the members on this forum pack up and leave for something newer, I will have a shaken belief on arduino. But until then I have no fear that another clone will take over arduino. I think the arduino "asset" resides more on its community than any hard/soft/firm/not-so-firm/ware advantages and price differences.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
jcwoltz
#7
Jun 10, 2011, 10:07 am Last Edit: Jun 10, 2011, 10:09 am by J.C. Woltz Reason: 1
I fell for it and bought the MAX32. To me it is just another development board. The arduino "form factor" means very little to me. Both boards have the same advantage that the arduino has. You can program using arduino libraries, or you can program using native code for the chip. They both have their strengths, and areas of use. It doesn't mean I will go out and sell all my Arduinos and AVR chips. I will continue integrating various AVR mcus im the projects that they are right for. Maybe someday I will integrate a PIC32MX chip in a project, if that is what the project demands. More choices for the consumer are good. The fact that they want to use the arduino libraries can only mean the arduino team is doing a great job!
J.C.
phazed
Quote
Onions.
I for one am coming from a parallax bs2sx, I really prefer the resources and open source nature of the arduino.
zenwebb
You first have to understand that the term "Arduino" is kind of ambiguous for beginners, as it encompasses more technology than you might expect. "Arduino" can refer to the official board, the firmware for AVR ATMega chips, the programming language or the IDE you type that language into. It might be more accurate to say that Arduino actually refers to a big idea, of getting microcontroller technology into the hands of more people.
By that notion, the previous posters are completely correct: the more clones there are, the stronger Arduino is! Because the idea is carried forward. Personally, I have never bought an 'official' Arduino board, I've always used clones or made my own variants, and I don't think I'm supporting the Arduino initiative any less than other people.
I am pretty excited that Digilent has ported over some basic Arduino tech (shields and software ideas), but I'm sure its going to suffer from the same thing that plagued the microcontroller before the Arduino came along: crappy support, and zero community. PICs and AVRs have been around for a long, long time, but their users don't really share their work very often or form any coherent support network (AVRFreaks is probably the only exception I can think of). What makes Arduino so awesome is that anyone can come to these forums (or a handful of others around the internet) and get a discussion going. There's tons of energy and momentum going on with the Arduino community as a whole, which is part of what motivates hackers like me. I do hope the chipKIT gains some support and its users start showing off (and sharing) their projects, because a 32-bit processor is pretty darn cool. But since I don't want to figure out everything there is to know about those processors myself, I'm not going to be buying one just yet.
Creative technologist + OSHW engineer + lover of learning interested in bio+art+tech, form and digital fabrication
retrolefty
I do worry a little about the so called arduino "form factor compatablity" with the 32 bit boards. As any 32 bit board is bound to be a 3.3vdc board and most arduino boards and existing shields are 5vdc is there room for electrical damage here?
Lefty
westfw
PIC32 apparently has 5V-tolerant/compatible IO, except for the analog pins, which have added protection.
Just which shields ARE compatible with a 3.3V cpu, anyway, and how do you tell them to be so (rather than carefully level-converting the digital pins back up to 5V, for example.)  I suppose it would be easy if you just put 3.3V on the "5V" power pin and let things run, but pic32 (for example) carefully puts a real 5V there (which is one of the compatibility issues I was referring to.)
funlw65
#12
Jun 27, 2011, 02:38 pm Last Edit: Jun 27, 2011, 02:55 pm by funlw65 Reason: 1
Lefty
Indeed, Arduino can be in trouble if:
  • - there are supply problems and prices are increasing (or prices can't be lowered); - prices are already high
  • - all the projects which made Arduino famous will be fully adapted (or their authors will migrate) to Chipkit and other compatible boards - is happening already
Frustrations in making transition (software and hardware problems) to Arduino clones can strengthen the Arduino position. But, something must be done for sure. You can't just sit on your leader chair without progress. Still, 5Vcc is a barrier to many hobbyists and Chipkit example in adapting a 3.3V chip to be a 5V board is to be followed.
Also, "the model" Microchip is making in quietly supporting  the Chipkit boards with specialized engineers is definitely to be followed. I hope Atmel is reading (or someone pointing them to) this.
Vasi
Grumpy_Mike
Quote
These two statements are utter rubbish and show you don't know what you are talking about.
funlw65
#14
Jun 27, 2011, 03:30 pm Last Edit: Jun 30, 2011, 12:37 am by funlw65 Reason: 1
1. I'm relating to realities in my zone (is all what it matters).
2. For RepRap is there a project started for Chipkit boards. And expect more where speed is needed.
My post suggest progress to Arduino platforms (and that you can't ignore "the signs"). Google chose Arduino platform for their ADK assuring Arduino existance for a long time from now on but also here are more powerful (and cheaper?) platforms for that.
But I'm sure Arduino developers will take into account all of these.
Vasi
