Topic: Help with schematic: ICSP with ATMEGA328-AI and resonator. (Read 2848 times) previous topic - next topic
Casey Gross
I just want to post a picture of my schematic to see if you guys can spot something hooked up wrong. And I know the button is connected wrong I just haven't really set that up yet.
spycatcher2k
Hi, RST should be connected to vcc with a 10k resistor - sometimes the chip wont start if its not. Also if your not using serial (AND HAVE A BOOTLOADER) - connect Rx and Tx to GND.
Drew.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
floresta
Quote
Would you care to explain your reasoning behind this recommendation?
Don
Grumpy_Mike
You need to connect a 0.1uF capacitor to pin 20 and connect pin 18 to +5V. The push button is correct and will work if you enable the internal pull up resistors.
floresta
Quote
Your diagram shows a 'MEGA8-AI' for the processor number but your subject line indicates you are using an 'ATmega328-AI'.  I can't find a datasheet for either of these devices (with the AI suffix), but the pin numbers on your diagram do not match either the ATmega8 or the ATmega328.  Which one of us is confused?
Don
Simpson_Jr
Don
It's not correct for the 28 pin DIP-version, but agrees with 32 pin TQFP-SMD version.
floresta
Quote
I missed that since I haven't used anything except DIP version.  I wonder which version the OP is using?
Don
