Topic: Measuring Frequency on Arduino Mega 2560 (Read 2760 times) previous topic - next topic
smarcus3
This was very difficult to find.
To do this you need to download the library at ... http://www.pjrc.com/teensy/td_libs_FreqCount.html
Pin 47 is used to measure the frequency on the 2560 mega and cannot be changed. Here is sample code that will work with the arduino.
Code: [Select]
/* FreqCount - Example with serial output
* NEED TO USE D IO PIN 47 FOR FREQUENCY INPUT FOR 2560 MEGA!!!!!!!!
* http://www.pjrc.com/teensy/td_libs_FreqCount.html
* This example code is in the public domain.
#include <FreqCount.h>
  FreqCount.begin(1000);
  if (FreqCount.available()) {
    unsigned long count = FreqCount.read();
    Serial.println(count);
BwBw
can i change the pin number . I am using tft screen therefore 47 pin is used by my tft.
