Topic: Linear Actuator Control (Read 1 time) previous topic - next topic
peter1929
Hello All , newbie here.
I have just started with arduino and was look to see if the might be a sketch around that would read the pulses from a linear actuator encoder and allow the actuator to only move a preset distance determined by the pulses counted.  eg  a 300mm actuatore and only want it to move 275mm.
peter1929
http://www.timotion.tw/product_01_actuator.php
The Actuator is the TA2
with hall sensor fitted.
Great unit in Australia contact www.techome.com
hope this helps
peter1929
yes i am going to use a mosfet h-bridge for control, just looking for any help on where to start, or if any one had a sketch similar i could adjust to suit .
i will also be using the built in end position switches and as extra safety use current sensing and a time out function as a back up ( must get the position part going first )
can you point me i a direction ?
zoomkat
If you get the actuator with a pot instead of an encoder, you could control it like a servo.
Google forum search: Use Google Advanced Search and use Http://forum.arduino.cc/index in the "site or domain:" box.
peter1929
i have 6 pulses per mm of travel.
using internal limits switches for safety
current limit very easy just using a voltage divider on a analogue input.
