Topic: FTDI Basic Breakout can replace VDIP1? (Read 1 time) previous topic - next topic
kty1104
hello
I want to ask if USB Serial converter(FTDI Basic Breakout - 5V) can replace VDIP1.
there are some document about
Arduino pro mini <-> VDIP1 <-> USB device(e.g. mini wireless lan card)
but I can't find any document about
Arduino pro mini <-> USB Serial converter(FTDI Basic Breakout - 5V)<-> USB device(e.g. mini wireless lan card)
does USB Serial converter(FTDI Basic Breakout - 5V) can replace VDIP1?
it seems both of two use same FTDI chip
FTDI Basic Breakout - 5V looks like this
http://cgi.ebay.com/FTDI-Basic-Breakout-5V-New-Model-suits-Arduino-/290530764078?pt=AU_B_I_Electrical_Test_Equipment&hash=item43a4fba52e#ht_2298wt_905
VDIP1 looks like this
http://common.leocom.jp/datasheets/140428_63955.pdf
thank you!
johnwasser
VDIP1 us a USB Host controller that lets you connect USB devices (thumb drives, mice, keyboards, network adapters, and other peripherals) to a system.
The FTDI Basic Breakout is a USB Serial Port Adapter which lets you connect a TTL Serial port to a USB Host.
They are not interchangeable.
CrossRoads
So John,
If I wanted to make a device that could play MP3s from a portable hard drive such as Western Digital 500GB , this FTDI  part would be a good start?
Robert
johnwasser
My understanding, from the product description, is that the Vinculum and Vinculum-II  products from FTDI Chip provide a USB Host interface that would allow you to read data from a USB hard drive.
http://www.ftdichip.com/Products/ICs/VNC1L.htm
http://www.ftdichip.com/Products/ICs/VNC2.htm
Of course the ATmega processors that have built-in USB capability might also be a good choice.
CrossRoads
Are any of the ATmega processors that have built-in USB capability  also supported in the Arduino IDE?
johnwasser
I don't know but I wouldn't be surprised if the ATmega16U2, 16U4, 32U2 or 32U4 were close enough to the ATmega168 or 328 to be easily adapted to the Arduino IDE.   I think they only come in surface-mount packages. :(
