North Yorkshire, UK
Offline
Faraday Member
« Reply #15 on: June 06, 2011, 02:10:17 pm » |
Grumpy_Mike - so what is your definition of code? (source code?) No it is not. It is text that gets interpreted. Yes but so is all code - javascript is simply human readable text that gets interpreted...
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #16 on: June 06, 2011, 02:19:51 pm » |
(source code?) No source code isn't code - it is the source of the code hence the name! Code is machine instructions. Source code is the source, used by a compiler, to produce code. Bitlash is just text that is interpreted by another program, it is not code.
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #17 on: June 06, 2011, 02:22:04 pm » |
Ahh but that's what most people refer to when talking about code - you're just being pedantic. Bitlash is therefore source code yes? C++ is then not code but still source code? Are we happy now?
Logged
Offline
Brattain Member
« Reply #18 on: June 06, 2011, 02:24:51 pm » |
Ahh but that's what most people refer to when talking about code Doesn't stop them from being wrong does it, just because a lot of people are wrong.
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #19 on: June 06, 2011, 02:25:50 pm » |
Glad we agree now...  Living up to your name tonight - didn't want to let us down
Logged
0
Offline
God Member
« Reply #20 on: June 06, 2011, 02:31:22 pm » |
bytecode=pcode=portable code. If you put logic on the sd card, it is code. It doesn't matter if it is interpreted or run as-is through the cpu. It doesn't matter if the codes are human readable like a programming language.
Maybe you are thinking of machine code? a specific name for code that is compiled/assembled?
This is a vastly different scenario than plain data.
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #21 on: June 06, 2011, 02:38:49 pm » |
Ok war over - yes it's possible to both load hex onto an arduino and run a type of text based code (source code perhaps) from an SD card but it is not possible with the current hardware architecture to load programs directly off of an SD card, using the SD card as external flash memory for them.
Logged
Global Moderator
Boston area, metrowest
Online
Brattain Member
Available for Design & Build services
« Reply #22 on: June 06, 2011, 02:48:17 pm » |
Well, that was certainly an interesting discussion to follow!
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #23 on: June 06, 2011, 03:11:09 pm » |
Logged
Global Moderator
Online
Brattain Member
« Reply #24 on: June 06, 2011, 03:43:37 pm » |
Oh, that is nice! Awesome way to update embedded systems.
Logged
0
Offline
God Member
« Reply #25 on: June 06, 2011, 05:59:14 pm » |
lol, I'm still trying to get over the commenters avatar
Logged
NZ
Offline
Sr. Member
Turtle in a hard shell
« Reply #26 on: June 06, 2011, 08:53:09 pm » |
I must have/make one. That will be incredibly useful Thanks for the link!
Logged
