Topic: Multiple Pushbuttons with Toggle (Read 717 times) previous topic - next topic
MistrPibb
I coded a simple synth where
Pitch = sensor value * 2
But then I gave it a shot to make it more interesting.
I want to have 4 toggle-able pushbuttons which replace the "multiplier" with a variable multiplier.
This way, depending on what button was pressed last, the pitch is unique from the others.
I sort of left the coding at a cliffhanger.
Any help or advice at all really is appreciated
Code: [Select]
//declare variables:
const int b1Pin = 3;
const int b2Pin = 4;
const int b3Pin = 5;
const int b4Pin = 6;
int varPin = analogRead(A0);
int button1 = digitalRead(b1Pin);
int button2 = digitalRead(b2Pin);
int button3 = digitalRead(b3Pin);
int button4 = digitalRead(b4Pin);
int lastButtonPressed = 1;
int currentButton = 1;
int buttonState = 0;
int lastButtonState = 0;
void setup(){}
 //Button input changes variable currentButton
 if (button1 == HIGH)
 {currentButton == 1;}
 if (button2 == HIGH)
 {currentButton == 2;}
 if (button3 == HIGH)
 {currentButton == 3;}
 if (button4 == HIGH)
 {currentButton == 4;}
 if (currentButton != lastButtonPressed) //If new button isn't the same as last
 {lastButtonPressed = currentButton;}    //Change it to new value
 int varPitch = map(varPin, 100, 1000, 100, 5000) * lastButtonPressed;
 //Pitch will equal sensor value times the "button multiplier".
 tone(7, varPitch); //Play it.
dcb
I havent scanned the whole thing but this did jump out at me:
should be: (one equals sign for assignment)
 {currentButton = 1;}
You have a few of them like that.
MistrPibb
Yeah, I must've overlooked it.
Thanks for catching that.
