Loading...
Pages: [1]   Go Down
Author Topic: Multiple DHT11 Sensors  (Read 1579 times)
Offline Offline
Newbie
View Profile
Hi Forum,
I am new to Arduino.
I am interested in connecting 8 x DHT11 to Ardunio Mega.  Is this possible?
I am a software engineer, not an electronics person.  Do I need anything special - such as pull up resistors for each DHT11 I connect?
The DHT11 - I am planning to connect are http://www.australianrobotics.com.au/products/electronic-brick-digital-temperature-humidity-sensor-dht11
How do I address each DHT11 or am I just reading from Digital IO 0-7 on the board?
Thanks
Stuart
Logged
Central Europe
Offline Offline
Edison Member
Use the Source, Luke.
View Profile
Each sensor has it's own digital pin and you should connect the sensor signal pin directly to the Arduino-pin. Communication then is done by first setting the pin as output pin to tell the sensor to go ahead and send data, then the pin is reconfigured as input and the sensor pulls down the signal line for bits. As the sensors themselves seem to have a maximum date refresh rate of 2 seconds, you shouldn't be in any hurry to poll all sensors sequentially.
Korman
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
You cannot set the DHT11's on a single bus, the protocol looks a bit like the one-wire but it ommitted an addressing scheme. So you need one pin per DHT, (you can share the GND and 5V).  As the Arduino has more than 8 pins this is doable, or use a multiplexer as KE7GKP suggested.
Check - http://arduino.cc/playground/Main/DHT11Lib -
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
I am still having trouble translating the code from http://arduino-info.wikispaces.com/Cosm-Arduino to use the numbering scheme you show.
Can you provide any guidance as to where I have gone astray? (Code below)
Thanks!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
A quick hack
Code:
void loop()   /*** LOOP: RUNS CONSTANTLY ***/
  /*---( Read the DHT11 Temperature / Humidity Sensor, and check for errors. )---*/
  Serial.print("Sensor 2: ");
  int chk2 = DHT11_2.read(DHT11PIN2);
  switch (chk2)
  case  0:
    Serial.println("OK");
  case -1:
    Serial.println("Checksum error");
    delay(
  case -2:
    Serial.println("Time out error");
  default:
    Serial.println("Unknown error");
  Serial.print("Sensor 5: ");
  int chk5 = DHT11_5.read(DHT11PIN5);
  switch (chk5)
  case  0:
  case -1:
  case -2:
  default:
  if (chk2 == 0)
    OfficeTempC     =  (float)DHT11_2.temperature,2;     // Value from Sensor
    OfficeTempF     =  Fahrenheit(DHT11_2.temperature);  // Computed value from C
    OfficeHumidity  =  (float)DHT11_2.humidity;          // Value from Sensor
    OfficeDewPoint  =  dewPointFast(DHT11_2.temperature, DHT11_2.humidity); // Computed Value
    Serial.print("Office Temperature (oC): ");
    Serial.println(OfficeTempC);
    Serial.print("Office Temperature (oF): ");
    Serial.println(OfficeTempF);
    Serial.print("Office Humidity (%): ");
    Serial.println(OfficeHumidity);
    Serial.print("Office Dew PointFast (oC): ");
    Serial.println(OfficeDewPoint);
    datastreams2[0].setFloat(OfficeTempC);    // Set sensor values into datastreams 1
    datastreams2[1].setFloat(OfficeTempF);    // Set sensor values into datastreams 2
    datastreams2[2].setFloat(OfficeHumidity);  // Set sensor values into datastreams 3
    datastreams2[3].setFloat(OfficeDewPoint);  // Set sensor values into datastreams 4
    cosmReturn = cosmclient.put(feed2,cosmKey);   // Send feed to cosm
    Serial.print("COSM client returned : "); // Get return result code, similar to HTTP code
    Serial.println(cosmReturn);
  if (chk5 == 0)
    MBdrmTempC     =  (float)DHT11_5.temperature,2;
    MBdrmTempF     =  Fahrenheit(DHT11_5.temperature);
    MBdrmHumidity  =  (float)DHT11_5.humidity;
    MBdrmDewPoint  =  dewPointFast(DHT11_5.temperature, DHT11_5.humidity);
    Serial.print("Master Bedroom Temperature (oC): ");
    Serial.println(MBdrmTempC);
    Serial.print("Master Bedroom Temperature (oF): ");
    Serial.println(MBdrmTempF);
    Serial.print("Master Bedroom Humidity (%): ");
    Serial.println(MBdrmHumidity);
    Serial.print("Master Bedroom Dew PointFast (oC): ");
    Serial.println(MBdrmDewPoint);
    datastreams5[0].setFloat(MBdrmTempC);
    datastreams5[1].setFloat(MBdrmTempF);
    datastreams5[2].setFloat(MBdrmHumidity);
    datastreams5[3].setFloat(MBdrmDewPoint);
    cosmReturn = cosmclient.put(feed5,cosmKey);   // Send feed to cosm
  delay(2500); // Put a delay before the next updates to Cosm (2.5 Seconds)
}//--(end main loop )---
if you look at the code above it is "screaming" for some functions that handle the individual steps per sensor
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
That was a great step forward and much cleaner! Thank you!
I was able to integrate it and make the multiple sensors read separately but it won't execute the part to post to COSM. The data never hits the COSM site (tried the debug page there) nor does the SerialPrint show up in the Serial Monitor.
I attached the full file this time as it is too many lines for this forum when I tried to edit it down last time.
Any thoughts as to where I have gone astray on the COSM client stuff? Or am I really off base?
Thanks!!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Do a step back an make a sketch that posts just one value every 60 seconds on cosm. If that works scale it up.
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
