Loading...
Pages: [1]   Go Down
Author Topic: Attempting to run WebServer and getting error  (Read 260 times)
Buena Vista, CO
Offline Offline
Full Member
Arduino rocks
View Profile
I just bought a "LinkSprite CuHead WiFi Shield for Arduino" from CuteDigi. I am attempting to test it as described in the wiki page http://asynclabs.com/wiki/index.php?title=AsyncLabsWiki. I downloaded the library and installed it as directed and pulled in the WebServer example. It compiles just fine, but after downloading to the Arduino I get the error message:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
The only modifications I have made to the sketch is entering my SSID and passwords. My Arduino is a Duemilanove. Anyone, any ideas?
Jim
Logged
8000ft above the average
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
When this error message is printed, it is accompanied by a link to the Troubleshooting section. What steps have you tried there? With what results?
Typical errors are not selecting the right board and/or the right port, in the Tools menu.
The code does not get loaded on the shield. Are you able to upload code to the Arduino without the shield attached?
Logged
Buena Vista, CO
Offline Offline
Full Member
Arduino rocks
View Profile
These are the error messages exactly as received(copied from the information line).
I loaded a test sketch to the board and it ran perfectly(blinking led).
Jim
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
When I get this kind of avrdude errors I always check if I selected the right board and comport under the tools menu. If OK then I disconnect the Arduino for 5 seconds so the OS can refresh its internal administration..
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Buena Vista, CO
Offline Offline
Full Member
Arduino rocks
View Profile
I'm in the house right now, I try this when I go back to my observatory. Thanks!
Jim
Logged
Buena Vista, CO
Offline Offline
Full Member
Arduino rocks
View Profile
Of all the things you would never suspect, I had a bad USB cable.
Jim
Logged
Pages: [1]   Go Up
Print
Jump to:
