Topic: Power Supply (Read 2963 times) previous topic - next topic
AKSoapy29
Three batteries is only 4.5 volts, if each battery is 1.5 volts, which most are.
Andrew K.
jag3498
jag3498
jag3498
I am using the uno smd. I found a old broken ac adapter with a right sized barrel plug for arduino. If i cut the cable and striped the two wire could i connect a power source that way? if so what would the required voltage be.
jag3498
oops. I should of looked there first! would there a way to find out which wire is + and which is - for the barrel plug?
jag3498
but how can i know what wire is connected to the inside pin?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
