Loading...
Pages: [1]   Go Down
Author Topic: Read the itron 100g dl gas meter  (Read 1087 times)
Atlanta, GA
Offline Offline
Jr. Member
View Profile
so the meter - if you look closely you can see the gear that rotates in the attached pictures
I used the RadioShack Emitter and Detector #276-0142 set and some pvc and duck tape (to block the sun light and to hold it in place)
here's the meat of the code
because it get's full on sun I use filters for the cross over counts
Code:
#define gas_analog_in 4
#define gas_digital_out 4
    GasLoop();
unsigned long gasTotalCount = 0;
unsigned long gasLastCount = 0;
unsigned long gasG5count = 0;
unsigned long gaslastMillis = millis();
unsigned long gasReading = 0;
unsigned long gasReadingMax = 0;
unsigned long gasReadingMin = 1023;
unsigned int gasFlag = 0;
unsigned long gasTripHigh = 0;
unsigned long gasTripLow = 1023;
int gasTripOffset = 75;
float gasFilterL = 900;
float gasFilterOff = 900;
int gasOut = HIGH;
void GasLoop()
  gasReading = analogRead(gas_analog_in);
  gasFilterL += .01 * (gasReading-gasFilterL);
    gasReading = gasFilterL;
  if(gasReading>gasReadingMax) gasReadingMax = gasReading;
  if(gasReading<gasReadingMin) gasReadingMin = gasReading;
  if(gasReading<gasTripLow) {
    gasFlag = 1;
  } else if (gasFlag == 1 && gasReading>gasTripHigh) {
    gasFlag =0;
    gasTotalCount++;
  if (gasReading>gasTripHigh) {
    gasTripLow = gasReading - gasTripOffset;
    gasTripHigh = gasReading;
  if (gasReading<gasTripLow) {
    gasTripHigh = gasReading + gasTripOffset;
    gasTripLow = gasReading;
over the last two months I had:
BilledMyReading%Delta
1211.881.00%
1111.16-1.45%
so over the 2 months -0.17% (seeing they bill at 1ccf and I measure at .01)
I'm happy with results so far!
Logged
Calgary, AB
Offline Offline
Newbie
View Profile
Nice work!
My utility company has recently installed the 100G DLN wireless module on my gas meter (DL and LDN are the same except that the DLN has more power for fixed network reads...whatever that is).
I'd like to read the meter electronically and your solution seems to be the simplest. The option of reading it wirelessly seems more involved.
Can you provide a little more detail on how the gear rotation works to allow passage of the infrared? I see from the pictures how you have mounted it, but the details aren't entirely clear to me.
Thanks in advance!
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
so the meter - if you look closely you can see the gear that rotates in the attached pictures I could not see this.What does the IR beam do . Is it cut by the gear moving? I take it you have nothing inside the meter so how are your devices positioned
I used the RadioShack Emitter and Detector #276-0142 set and some pvc and duck tape (to block the sun light and to hold it in place)Its "duct" tape I think .How does this keep out the sunlight though?
because it get's full on sun I use filters for the cross over counts Could you explain this a bit more please?
Logged
Pages: [1]   Go Up
Print
Jump to:
