Loading...
Pages: [1]   Go Down
Author Topic: [SOLVED] Optional arguments not working - trying to avoid function overloading  (Read 235 times)
Offline Offline
Newbie
View Profile
Hi all,
I'm trying to write myself a function with optional arguments, and DO NOT want to use function overloading as it seems nonsensical in this case. I've tried to do it the normal way:
Code:
  writeString(String(selectedPattern));
// Given a string, this will write it to the display.
void writeString(String str,int delayTime = 0) {
  int StringLength = str.length();
  if(StringLength > 4 || StringLength == 0) return;
  for(int i=0;i<4-StringLength;i++) {
    Serial.write(0x78);
  for(int i=0;i<StringLength;i++) {
    Serial.write(str.charAt(i));
    delay(delayTime);
Compiling this, however, gives this error:
Quote
'writeString' was not declared in this scope
What am I doing wrong here? This is driving me nuts! I don't want to do function overloading as it's messy and takes up more space (for a single line of code too!) Removing the delay() and the default value in the call fixes it (but breaks it in another section where I define a delay).
« Last Edit: June 08, 2011, 07:00:01 am by montymintypie » Logged
Offline Offline
Newbie
View Profile
Strangely, a helper function actually calls writeString("TEST") at one point and it compiles fine! More to the puzzle...
Logged
Arlington, MA, USA
Offline Offline
Sr. Member
View Profile
Try defining writeString before loop
Logged
Offline Offline
Newbie
View Profile
That fixed it... Seeing as the other function worked fine, I assumed it was something like that, just never thought to put it before loop(). Thanks!
Logged
Pages: [1]   Go Up
Print
Jump to:
