Minnesota!
I'm on YouTube! Search AKSoapy29
« on: June 08, 2011, 12:06:10 pm » |
Hello. Can I run my Arduino Uno off of 12 Volts DC? And if I can, how?
Manchester (England England)
Solder is electric glue
« Reply #1 on: June 08, 2011, 12:15:25 pm » |
Put the 12V in the DC input jack. If you are running other stuff as well off the 5v line the regulator might get hot and need a bit of an extra heat sink.
Minnesota!
« Reply #2 on: June 08, 2011, 12:23:26 pm » |
Ok. I've seen people plug a battery pack strait into the controller. Does that have to be 5 volts, or is it a different power level?
Minnesota!
« Reply #3 on: June 08, 2011, 12:28:06 pm » |
Ah Vin.
Minnesota!
« Reply #4 on: June 08, 2011, 12:29:21 pm » |
So how would you add an extra heatsink? Anything special I would need to use? I mean, I don't want to damage my board.
Boston area, metrowest
« Reply #5 on: June 08, 2011, 12:42:53 pm » |
What controller? Heatsink - something that would help dissipate the heat from the regulator without shorting anything in the area. Maybe a version of something like this http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=HS179-NDIdeally you would have a switching regulator to take the 12V down to 5V and connect it to the 5V header pin.
Minnesota!
« Reply #6 on: June 08, 2011, 12:47:52 pm » |
I know what a heatsink is, and I said Uno above.
Yeah that one might work. And I only would like to use one powersource, which is 12 volts to run everything. Most stuff I have hooked up to my Arduino is 12 volts, but the RFID Reader is 5v-16v. Barely getting by with that. So that's why I would like 12 volts to also power the relays and other stuff.
« Reply #7 on: June 08, 2011, 12:55:48 pm » |
If the "other stuff" is 12V, that power wouldn't be going thru the arduino, so the regulator should be okay unless you start driving lots of LEDs or something that will also need 5V.
How are the relays turned on/off? Are those 5V parts, or do have transistors/ULN2003/etc to drive them?
When you said controller, I thought you might have meant a motor controller or something, was just a little funny seeing the arduino referred to as a controller.
Whatever you do for the heatsink, be careful not to short anything.
Minnesota!
« Reply #8 on: June 08, 2011, 01:01:07 pm » |
That's what I'm wondering. How and where do I add the heatsink. And I'm driving the relays with 2n2222 transisters. And I'm using an Altronix 12 volts power source, so I think I'm good there. I'd be running the relays and RFID Reader off of it.
« Reply #9 on: June 08, 2011, 01:02:46 pm » |
How and where do I add the heatsink. Glue it on the top of the regulator.
Minnesota!
« Reply #10 on: June 08, 2011, 01:07:11 pm » |
Any spesific type of glue? Or just hot glue? And is the regulator the transister looking thing between the power jack and the usb hub?
« Reply #12 on: June 08, 2011, 01:13:25 pm » |
Search digikey for "thermal adhesive" Not Silicon Grease tho.
Wow, that stuff is expensive! I'd be tempted to go withthe slip, with some insulating tape on the bottom of the board to avoid shorts.
You have the relays & stuff on a piece of perfboard or something? I would add the regulator there and just bypass the one on board.
Minnesota!
« Reply #13 on: June 08, 2011, 01:15:33 pm » |
Maybe Radioshack has a 12-24 volts > 5 volts or something like that. I'll look on there site. No, I just have regular din rail relays.
Minnesota!
« Reply #14 on: June 08, 2011, 01:18:24 pm » |
Radioshack does! And it's pretty cheap to. http://www.radioshack.com/product/index.jsp?productId=2062599I should go pick that up and figure out how to wire it. Can I put power strait into 5 volts on the Arduino, or will it reject it? I'd think it wouldn't reject it, but wouldn't be enough @ 1A.
