Topic: what is the max rpm an auduino can read? (Read 3014 times) previous topic - next topic
jraskell
The question still remains, what are you doing with the value that requires that kind of resolution?
robtillaart
How about adaptivity?
- if the RPM is high there is less need to know the angle e.g. 8 pulses per rotation is ok?
- if the RPM is low the angle position becomes more important and more pulses are used.
Have not thoughed about how to build that (sort of digital gearbox I guess)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Gadget999
the number is used to determine the firing angle of an engines injectors
the engines that rev to 50,000 rpm use carbs so the angle is not important
Mori
Quote
i was recommended 100 pulses per rev by a guy who has been doing this stuff since the 1960's
So how did he do this back before Arduino (or micro-controllers, or even computers, for that matter)?
hmm barcodes, atms, apalo 11,  avionics
sry there was some of it at least
AND THE FIRST WORKING LASER
Memento Mori
Sola Christus
The Christian Hacker:
https://www.facebook.com/groups/141258275980190/
wildbill
It's quite hard to offer sensible suggestions without having this answered
robtillaart
Quote
(I assume) Mechanically, it is amazing what is possible with gears - although an "adjust and recompile of a gearbox" can take many days. By adding bigger cogwheels with more teeth, change of transmissions, etc precission is incremented.
Rob Tillaart
Gadget999
i found this video some of you may like
120,000 rpm with the arduino !
http://www.element14.com/community/videos/1648
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
