Topic: TC2004a (Read 2673 times) previous topic - next topic
AJB2K3
http://www.oppod.com/LCM_SPEC%5CCharacter%5CTC2004A.PDF
I have one of these and tried the LCD hello world sketch but nothing appeared on the lcd
Is this device a compatible display with this script?
Sorry for the noobish post but my knowledge is 10 years out of date!
Grumpy_Mike
Yes it looks a dead ringer for a standard LCD display. Perhaps the is an error in the wiring.
floresta
It should work if you do everything correctly.  Try following the tutorial at http://www.ladyada.net/learn/lcd/charlcd.html.  Don't skip any steps and don't proceed to the 'Bus Wiring' section if you don't get the single row of blocks (two rows in your case) about midway through the tutorial.
Don
AJB2K3
Thanks,
booked marked,
Got the backlight to work but not the first line, must have duff pot wiring.
AJB2K3
Thanks, It's not the pot is the top bus rail on my plugblox (or what ever there called)
The top 2 rails don't run the whole way  :smiley-eek: :smiley-eek:
Just need some more plug wires for the com lines.
floresta
...is the top bus rail on my plugblox (or what ever there called)
It's called a 'solderless breadboard'.
Some do, some don't...
Don
AJB2K3
Ok thanks,
Don
Bit of putting finding that out (thought the display was duff)
All sorted now and all working (for the first time since I got the thing)
Thanks all.
