Loading...
Pages: [1]   Go Down
Author Topic: Strange problem with Op-amp  (Read 220 times)
Offline Offline
Newbie
View Profile
I have tried to connect a microphone to arduino's analog input thought op-amp (LM741), I used the following circuit (image attached). The problem is that I get always the same value 840. I tried to replace the mic with DC motor and rotate it, but same problem ( i got value of 240 ). I'm not sure that there is a problem with the chip, I tested it as voltage follower and it worked perfectly.
What have I done wrong?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The LM741 uses +/-15V split supplies.  It doesn't work at all with a 5V single rail supply.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Also that circuit can't possibly work as even the most advanced opamp can't take its output voltage below the negative supply rail.
Logged
Offline Offline
Newbie
View Profile
yes, i know i just want to detect noise.
Thanks, I switched to LM324, it solved the problem.
Logged
Pages: [1]   Go Up
Print
Jump to:
