Topic: NTC Thermistor vs LM35 (Read 7893 times) previous topic - next topic
Gadget999
Wanted to ask some opinions on the pro's and cons of each
RuggedCircuits
Thermistors are very cheap, in the ballpark of $0.20. They're not very precise and their resistance change with temperature is non-linear, so you have to do a little "work" in your software to figure out the temperature.
Active devices like the LM35 are more expensive (>$1) but are more precise and provide a linear voltage-vs-temperature characteristic making it easier to figure out the temperature.
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
johnwasser
The LM35 is calibrated.  The thermistor has to be calibrated against some known-good temperature standards.
illillillill
if you want the temperature in Celcius and i have the LM35, just use this code:
tempC = analogRead(tempPin);
  tempC = (5.0 * tempC * 100.0)/1024.0;
and u'r pretty much all set,  with the NTC/PTC u'll need to make a circuit and even then you wont be able to do anything nearly as simple as this code.
Gadget999
cheers for the code
is there any other alternative other than a thermocouple that can read a higher temperature
illillillill
you want to read above 155C ?
you could try this:
http://www.omega.com/rtd.html
but i dont know anything about it. i can just see the ratings.  if you need more advanced help on temperature i can refer you to the sensor forum in arduino: http://arduino.cc/forum/index.php/board,10.0.html
Gadget999
ty
looks like a good alternative
