Topic: Interfacing finger print scanner with Arduino (Read 716 times) previous topic - next topic
RBR
Hi
I am trying to communicate finger print scanner sm 630 with arduino. Is there any library available?
Please reply if anyone had already done this .
johnwasser
According to the product description (http://www.miaxis.net/1070015/1/12/products_details.htm?menu=1) it speaks TTL Serial at 57600 baud.  Should be fairly easy to interface with the hardware serial port (pins 0 and 1) or possibly a NewSoftSerial.h software serial port.
Did you get any useful documentation with the unit?
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
RBR
#2
Jun 10, 2011, 04:00 am Last Edit: Jun 10, 2011, 04:01 am by RBR Reason: 1
ya, I am having the data sheet.The communication is serial with baud rate 57600.But it needs to send a hex code like this "EF01FFFFFFFF010003010005" to generate template and similar code to search for a match.
I tried to communicate . But no response from other side. Thats why I asked is there an library available?
johnwasser
No library that I could find.  It looks like a simple enough interface that a library might be excessive.  Try it like this:
Serial.print(0xEF, BYTE);
Serial.print(0x01, BYTE);
Serial.print(0xFF, BYTE);
//  Etc...
