Loading...
Pages: [1] 2   Go Down
Author Topic: Creating a Circuit with Ultrasonic transducers  (Read 1439 times)
Offline Offline
Newbie
View Profile
Hey all,
I recently ordered a set of long range ultrasonic transducers from here: http://www.futurlec.com/Ultrasonic_Sensors.shtml
I was wondering if anyone can offer any advice on how I can hook these up to start reading distances.
Thanks in advance
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Send out an ultrasonic pulse and measure how long it takes for the pulse to bounce back.
Logged
Offline Offline
Newbie
View Profile
Can you be more specific? I am very new to programming and working with the arduino. It is my understanding that I need to feed 40khz into one, then amplify the other and listen for a reply(they came in a pack of 2). I am not quite sure how to make this happen though.
Thanks.
Logged
Offline Offline
Jr. Member
View Profile
For another $6 you can buy a pair of sensors mounted on a circuit board complete with its own microcontroller.
For a beginner it makes interfacing with so much easier as you can use the existing ping library.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Agree with mjbmikeb - unless you have access to, and know how to use an oscilloscope, these things are tricky to build and debug, with echoes typically only producing signals in the millivolt range.
If you're looking for circuits, google "devantech srf04" - the circuits used to be freely available, but be aware that they use a PIC, not an AVR to drive them.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Ok, i'll look into that. The reason I chose those sensors is because of the range approx. 18m where as the Devantech SRF04 only has a range of approx. 3m. I figured I would just get those sensors and build around them.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
18 metres is an awfully long way for ultrasound.
You'll need to put some real power into the transmitter.
In a cluttered environment (and most will be out to that sort of range and beam angle) expect lots of multipath returns.
« Last Edit: June 10, 2011, 09:10:59 am by AWOL » Logged
Offline Offline
Newbie
View Profile
Well the basic idea for the thing i am trying to build is to keep track of the distance a moving object is from the point of origin. From approx 18m to lets say around 3m
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
How big is the "moving object"?
Logged
Offline Offline
Jr. Member
View Profile
The easy way is to buy a $150 laser range finder as used by golfers. (These have a minimum range of 5m.)
The more interesting way....
Vehicle has a wireless "camera remote shutter control", Arduino, microphone and 40kHz band pass filter.
The origin has the corresponding wireless receiver, another Arduino to generate a 40kHz square wave bust, a cheap 100W public address amplifier turned up full, and a 50W piezo tweeter.
Fit ear plugs, (the tweeter will probably make loud clicking sounds.)
Trigger a pulse from the vehicle and measure the time for the sound to be received.
Calibrate for 3 and 18m.
Reduce the transmit power until it just works at 18m and remove ear plugs.
Logged
Offline Offline
Newbie
View Profile
Lets say the size of a car.
Logged
Offline Offline
Newbie
View Profile
any ideas about what I need to get these particular ultrasonic sensors to work? I already bought them so I might as well use them. I read somewhere that I could use an LM833 as an amplifier and a MAX232 to provide a larger voltage to the sensors in a circuit similar to this one: http://www.robot-electronics.co.uk/htm/srf04tech.htm however is there anything else that I would need on top of that to make this work?
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Go here - check out raron's posts:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1224198029
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
I just noticed that the images in the old forum for that post don't come up properly (they're too tiny to read) - here is raron's user profile on here:
http://arduino.cc/forum/index.php?action=profile;u=11873
He seems like he is still active - so maybe he might post up something; if not, I'm pretty sure I snagged a copy of that thread and the large images, maybe I can repost them somewhere...
Logged
Offline Offline
Newbie
View Profile
awesome. that looks like it will help a lot. Thanks
Logged
Pages: [1] 2   Go Up
Print
Jump to:
