Topic: Correct capacitors for Voltage Regulator ? (Read 861 times) previous topic - next topic
DaveO
Hi All
Needing to drop 13.8v to 5v to power my Arduino.
Have done some searching and found the following Voltage Reg : LM7805CT : Reg Standard Lin Fix Pos 5V 2.2A 3TO-220
http://za.rs-online.com/web/search/searchBrowseAction.html;jsessionid=82C6E2B70526385B1B04E30C1534E22D.212?method=updateShoppingCart
In the data sheet, I think I understand correctly that I need 2 capacitors : 0.33uF and 0.1uF.
Can anyone please confirm for me that the following 2 items are in fact the correct thing :
http://za.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6842229
http://za.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6842213
TIA.
jackrae
Yes they will work but VASTLY overpriced and over-rated for what you need.  These are rated at 850volts DC.  All you need are something rated at 50 volts maximum - you'll find 100 volts or so pretty standard and cost less than £1 each. Something like this, though you'll find them much cheaper at the likes of Maplins
http://cpc.farnell.com/vishay-bc-components/2222-368-25334/capacitor-330nf-100v/dp/CA00694
jack
illillillill
Top link is 0,33 µF
bottom link is 0,1µF
is this what you wanted to know ?  these are pretty pricy though,
DaveO
As long as they will suit the job, I will have to use them. Availability of choice in Africa is a bit limited, and we have a huge government surcharge on imported goods.
Exchange rates at the moment are about 1:11, so our R13.00 is about £1.18
Thanks
Chagrin
.1uF (100nF) ceramic: http://za.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5381449
.33uF aluminum: http://za.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0116975
Much cheaper.
DaveO
Much cheaper.
Thanks a million, Chagrin. I have changed my order on your suggestions.
Sometimes it's a bit difficult finding the right component, especially as a newbie and not knowing how everything in the online stores is classified.
Again, my Thanks.
Dave
