Loading...
Pages: [1]   Go Down
Author Topic: Gameduino polyphonic organ.  (Read 920 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
I got a gameduino yesterday, and though i would test out the synth engine.
8 voice polyphonic, and each voice can have 8 partials "organ stops" (they are fixed at the moment, ill add some potentiometers to change the sound)
you will need a MIDI input, or change it to receive MIDI from your computer via USB (dont ask how to do that, but i know you can)
Code:
//Gameduino has DC on the output. you should put a capacitor on the outputs if your monitoring system is DC coupled.
//Polyphonic gameduino organ 0.00000001
//june 2011 J.Matheson [DeFex][Neutron7]
#include <SPI.h>
#include <GD.h>
#include <MIDI.h> //avaliable from arduino playground
byte vo[] = {
  0,0,0,0,0,0,0,0}; //polyphony voice array
byte voFlag[] = {
  0,0,0,0,0,0,0,0}; //polyphony active flags
byte voActive; //total of active notes
byte counter1;
byte playNum;
byte vel;
unsigned int MIDItoGDFREQ[] = { //MIDI to frequence x 4 rounded.
  33,35,37,39,41,44,46,49,
  52,55,58,62,65,69,73,78,
  82,87,92,98,104,110,117,123,
  131,139,147,156,165,175,185,196,
  208,220,233,247,262,277,294,311,
  330,349,370,392,415,440,466,494,
  523,554,587,622,659,698,740,784,
  831,880,932,988,1047,1109,1175,1245,
  1319,1397,1480,1568,1661,1760,1865,1976,
  2093,2217,2349,2489,2637,2794,2960,3136,
  3322,3520,3729,3951,4186,4435,4699,4978,
  5274,5588,5920,6272,6645,7040,7459,7902};
struct voice //left from original gameduino sketch, not used except for initialization
  float f;
  float a;
voices[16];
void load()
  byte v;
  unsigned int gg = 0;
  float sum = 0.0;
  for (v = 0; v < 16; v++) {
    sum += voices[v].a;
  float scale = 255.0 / sum;
    byte a = int(voices[v].a * scale);
    GD.voice(v, 0, int(4 * voices[v].f), a, a);
void note(byte voActive,byte m,byte vnum, byte velo)
  int offset = vnum<<3; //add 8 to the voice numbers for each polyphonic voice
  if (velo > 0){
    int level = 32;//this could be dynamically changed by velocity
    unsigned int n = MIDItoGDFREQ[m];
    unsigned int n2 = n + 2; //slight detuning of some oscillators
    GD.voice(offset+0, 0, n, level>>1, level>>1); //mess around with these,
    //everything together should not add up to more than 356 / the number of voices playing
    GD.voice(offset+1, 0, (n<<1), level>>2, level>>2);
    GD.voice(offset+2, 0, (n*3)-4, level>>3, level>>2);
    GD.voice(offset+3, 0, (n<<2)-7, level>>2, level>>3);
    GD.voice(offset+4, 0, (n*5), level>>5, level>>5);
    GD.voice(offset+5, 0, n2, level>>2, level>>2);
    GD.voice(offset+6, 0, (n2<<1)+4, level>>1, level>>1);
    GD.voice(offset+7, 0, (n2<<1)+9, level>>2, level>>2);
  else{ //note off
    GD.voice(offset+0, 0, 0, 0, 0);
    GD.voice(offset+1, 0, 0, 0, 0);
    GD.voice(offset+2, 0, 0, 0, 0);
    GD.voice(offset+3, 0, 0, 0, 0);
    GD.voice(offset+4, 0, 0, 0, 0);
    GD.voice(offset+5, 0, 0, 0, 0);
    GD.voice(offset+6, 0, 0, 0, 0);
    GD.voice(offset+7, 0, 0, 0, 0);
  int i;
  delay(250);
  GD.begin();
  MIDI.begin(MIDI_CHANNEL_OMNI);
  MIDI.setHandleNoteOn(HandleNoteOn); //for the MIDI.h library
  MIDI.setHandleNoteOff(HandleNoteOff);
  //GD.MODULATOR = 32;
void HandleNoteOn(byte channel, byte pitch, byte velocity) {
  voActive = 0;
  for (counter1 = 0; counter1 < 8; counter1++) {  //count through the polyphonic voice array and find an empty slot.
    if (voFlag[counter1] == 0){
      vo[counter1] = pitch;
      voFlag[counter1] = 1;
      playNum = counter1;
    if (voFlag[counter1] == 1){
      voActive ++;
  note(voActive,pitch,playNum,velocity);
  if (velocity == 0) {
      if (vo[counter1] == pitch){
        vo[counter1] = 0;
        voFlag[counter1] = 0;
        playNum = counter1;
        note(voActive,0,playNum,vel);
        // This acts as a NoteOff on some controllers
void HandleNoteOff(byte channel, byte pitch, byte velocity) {
      vo[counter1] = 0;
      playNum = counter1;
      // This finds any notes that match the note number
      //in the polyphony array and turns them off.
  MIDI.read();  //could put LFOs, modulation, envelopes and stuff in here.
Logged
Offline Offline
Newbie
View Profile
Im looking for a good game for my xbox 360 key. I have oblivion but i finished and now im looking for another great game. PS3 JailbreakWhat game can i get thats long and very fun and interactive, I do have internet so internet games can b suggested as well, thank you.
Logged
Pages: [1]   Go Up
Print
Jump to:
