Loading...
Pages: [1]   Go Down
Author Topic: Flexible light sensor  (Read 281 times)
Offline Offline
God Member
a, b = b, a+b
View Profile
WWW
Hi Gang
Hi People of The Arduino Forum
For a project I am working on I need a sensor which can detect IR light. However this sensor needs to be flexible and small. Ideally I would like to mount an entire array of these sensors on something as flexible as a sheet of paper.
All I came up with is using surface mount components, which should work as they are tiny. However, a truly flexible solution would be cool.
Does anyone have any ideas?
Thanks
p.
« Last Edit: June 11, 2011, 05:54:20 pm by fkeel » Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
We're a gang now?
Can we have gang signs too?
I can't think of anything to suit what you're looking for. What's the application?
« Last Edit: June 11, 2011, 06:37:28 pm by mowcius » Logged
Offline Offline
Full Member
View Profile
Depending on what the application, the size of the sensor array and the needed flexibility is, a possible solution could be to use fibre optics on the flexible input side and have them transfer the light to a static sensor.
But to give you any truly viable input we would need to know a little more on what it is you intend to do...
Logged
Pages: [1]   Go Up
Print
Jump to:
