Loading...
Pages: [1]   Go Down
Author Topic: Serial Monitor Problems, Please Help  (Read 252 times)
Offline Offline
Newbie
View Profile
Hello all,
Newbie here,
I was trying to make the serial monitor output to my windows computer using a USB connection.  I was initially just going to output the data being read in on an analog output.  I couldn't make that work. Then I put in a line just to output Hello World. Niether are coming on the serial monitor.  I looked at the language reference to no avail.
Please Help.  The code is here:
Quote
int counter = 0;
 int sensorPin = A0;
 int sensorValue = 0;
  pinMode(A0, INPUT);
  pinMode(10, OUTPUT);
  pinMode(2, OUTPUT);
  Serial.begin(9600);      // open the serial port at 9600 bps:
  // PWM Code
  while(counter < 50)
   digitalWrite(10, HIGH);
   delay(5);
   digitalWrite(10, LOW);
   delay(5);
   delay(50);
   // Thermostat Circuit
   //Serial.print(Hello World);
   Serial.print("Hello world.");
   sensorValue = analogRead(sensorPin);
   Serial.print(sensorValue,DEC);  // Output to the serial monitor
   if (sensorValue < 50) //500 is original Value for the temperature input
    digitalWrite(2, HIGH); // turn fan on
    digitalWrite(2, LOW); // turn fan off
« Last Edit: June 13, 2011, 11:37:35 am by power453c » Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Code:
  while(counter < 50)
   delay(5);
   delay(5);
What is the value of counter when the while loop is entered?  What is the value of counter for the second pass through the while loop?
Logged
Arizona USA
Offline Offline
Newbie
Retired 35 years as programmer/engineer
View Profile
Move the hello, world print to the setup function. Just after the Serial.begin.
Also, I put a delay(2000) immediately after the Serial begin to allow time for me to activate the Serial Monitor. Not sure if needed.
In any event, moving the hello, world OUTSIDE all the analog stuff will tell you if you have a printing problem or a 'something else' problem.
  --jim
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The rest of us are. It isn't. Opening the Serial Monitor resets the Arduino, if the Arduino has not been modified to prevent that.
Logged
Offline Offline
Newbie
View Profile
Thanks all, the printer does now print the first line.  I modified the code accordlingly:
int counter = 0;
 int sensorPin = A0;
  pinMode(A0, INPUT);
  pinMode(2, OUTPUT);
  Serial.print("This is a test");
  // PWM Code
  while(counter < 50);
   Serial.print("pin 10 is high");
   delay(5);
   Serial.print("pin 10 is low");
   delay(5);
   delay(50);
   int counter = 0;
   Serial.print("counter is now reset");
  digitalWrite(13, HIGH);
   Serial.print("Hello world it's temperature measurement Time.");
    Serial.print("Fan is now on");
    Serial.print("Fan is now off");
    digitalWrite(13, LOW);
Problem now is only the first line prints, then it seems to stall in the while loop.  Any thoughts on how to get it past this one.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Go back and read all the replies. There is nothing in the while loop that changes the value of counter, so the while statement is always true.
Logged
Pages: [1]   Go Up
Print
Jump to:
