Topic: speed of PWM ? (Read 1 time) previous topic - next topic
Gadget999
I read that the The frequency of the PWM signal is approximately 490 Hz
can this be made faster ?
is there a shield that operates at a faster frequency ?
Grumpy_Mike
Quote
Yes
http://www.arduino.cc/playground/Code/PwmFrequency
Quote
To do what?
Gadget999
#2
Jun 14, 2011, 09:16 pm Last Edit: Jun 14, 2011, 09:30 pm by Gadget999 Reason: 1
cheers for the link
it is to control a fuel injector,
its a shame you loose the time functions
can two boards be connected togther to one does the timing and one does the pwm ?
Grumpy_Mike
Quote
Yes in any number of ways. It depends on how fast they need to communicate with each other.
You can use:-
I2C
SPI
Serial
Gadget999
ty
is there a shield / frame that allows you to plug them together ?
is there a limit on how many can be connected ?
Grumpy_Mike
Gadget999
do you daisychain them together with a ribbon cable to get them to work together ?
udoklein
You can generate PWM without loosing the time functions. You should take care to use only PWM that does not rely on timer0. Then the timer and PWM will not interfere at all.
Check out my experiments http://blog.blinkenlight.net
Gadget999
Grumpy_Mike
Quote
I2C - yes
Anything else - no
growler
With an UNO just pins 5 and 6 use the same timer0 for pwm.  As has been said you can change the timer settings for timer1 and timer2 without losing the arduino timing functions.
