Author Topic: speed of PWM ?  (Read 1066 times)
UK
Arduino - very interesting !
I read that the The frequency of the PWM signal is approximately 490 Hz
can this be made faster ?
is there a shield that operates at a faster frequency ?
Manchester (England England)
Solder is electric glue
Yes
http://www.arduino.cc/playground/Code/PwmFrequency
To do what?
UK
cheers for the link
it is to control a fuel injector,
its a shame you loose the time functions
can two boards be connected togther to one does the timing and one does the pwm ?
« Last Edit: June 14, 2011, 02:30:29 pm by Gadget999 » Logged
Yes in any number of ways. It depends on how fast they need to communicate with each other.
You can use:-
I2C
SPI
Serial
UK
ty
is there a shield / frame that allows you to plug them together ?
is there a limit on how many can be connected ?
No and no
UK
do you daisychain them together with a ribbon cable to get them to work together ?
20 LEDs are enough
You can generate PWM without loosing the time functions. You should take care to use only PWM that does not rely on timer0. Then the timer and PWM will not interfere at all.
UK
ty
I2C - yes
Anything else - no
Portland, OR
With an UNO just pins 5 and 6 use the same timer0 for pwm.  As has been said you can change the timer settings for timer1 and timer2 without losing the arduino timing functions.
